3-Point Hitch 4' or 5' tiller for CK20S?
   / 4' or 5' tiller for CK20S? #1
hfields
Kioti CK20
Need some advice from more experienced tractor owners.
I plan to buy a rotary tiller from Tractor Supply for my CK20S.
First, what service can one expect from the TS tillers? The 4' and 5' are the same price.
Second, I know the 5' model is too large for the CK20 but I planned to remove one set of tines to bring the width down to about 52". That way if I ever get a larger tractor I would have the larger tiller to match.
Or, should I just go with the 4' tiller as the 5' unit is about a 60lbs. heavier?
thanks for any advice.
   / 4' or 5' tiller for CK20S? #2
I think a 5 footer would be fine. I have a 52" Woods tiller and don't think a few more inches would bother it at all. Buy the larger one, you may need the extra width. At 52" it covers the tire prints by just a inch or so.
Good Luck
Eddie
   / 4' or 5' tiller for CK20S? #3
Unless you are working in very heavy clay soil, I would certainly get the 5 foot version. In low range the CK20 has a lot of grunt and should have no problem. If tilling new areas with heavy sod, you might have to overlap a foot or so on the first pass but the CK20 will do the job.
   / 4' or 5' tiller for CK20S? #4
4 ft in heavy soil and 5 ft in lighter soil. Ken Sweet
   / 4' or 5' tiller for CK20S? #5
I'd go with the larger one if your like most tractor owners you'll probably trade up some day
   / 4' or 5' tiller for CK20S? #6
I have a 50 inch Agric that I bought when I had my B6200 Kubota, it ran it quite well and my CK20 runs it way better. I have tilled some fairly heavy sodded soils and am confident a CK20 would run a 5 footer with little problem, in sod or really heavy soil you might just have to travel a little slower on first passes. Gary
Thanks very much for the opinions. I think I will go with the 5' as light soil is what i have to till.
   / 4' or 5' tiller for CK20S? #8
I ended up with a 60 inch KingCutter which works fine on my CT120 with 14hp at the pto in my peat/sandy loam soil with no rocks. The hydrostatic transmission allows me to adjust my speed to conditions. I can always remove some of the tines if I think there is not enough power and still be able to cover my tire tracks. Plus I feel that a 60 inch tiller will sell better when I give up gardening some time in the future (when I'm dead).
   / 4' or 5' tiller for CK20S? #9
jobguy;2927208 ..... The hydrostatic transmission allows me to adjust my speed to conditions..... [/QUOTE said:
   / 4' or 5' tiller for CK20S? #10
I have a 48" KK on my CK20 which I have used very hard and a lot of hours on it.( to the point most the blades are about half worn) . On anything but heavy wet clay you hardly know its there. If I start to bog down in clay or sod you just slow down. I almost wish I had bought a 5', I know it would handle it and I'm sure the newer 22hp models would in most cases. Go for it.
2014 Nissan Pathfinder SUV (A55853)
2014 Nissan...
2014 International Maxxforce DT (A53317)
2014 International...
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
