4 in 1 bucket tip
   / 4 in 1 bucket tip #71
Re: 4 in 1 regen. \"solution #4?\"
Thanks, I must have missed that part about the button earlier. So, when you press the button, which FEL function does it replace?
   / 4 in 1 bucket tip #73
Hi Mark,
To control the open/close operations on the 4n1 bucket you press the red button and move the FEL lever right/left.
With the red button pushed and a lever move left causes the bucket to close. If you want to open push the button and move the lever right.
Unless I got that backwards! :cool: Its hard to have to think HOW it works! Especially on a Monday morning! :cool:
FEL lever left dumps the bucket and lever right brings it back up.
Hope this helps...
Dan McCarty
   / 4 in 1 bucket tip #74
<font color=blue>Re: FEL lever left dumps the bucket and lever right brings it back up.</font color=blue>
That would be backwards from the way mine works, but then you have a John Deere, so maybe it's backwards./w3tcompact/icons/wink.gif
Bird
   / 4 in 1 bucket tip #75
Bird, Bird, Bird, Its those Orange Tractors that have things backwards! :cool:
I'm pretty sure I got it right, move FEL right and it dumps/closes. The backhoe's right control moved right digs. Move the same control left and it dumps. I think everything works the same.
Apparently I did not get it right this is what I should have said!
I'm pretty sure I got it right, move FEL left and it dumps/closes. The backhoe's right control moved left digs. Move the same control right and it dumps. Now that I'm totally confused and have no excuses since I HAVE had a Cup O Coffee, I'm going to go hide! I just asked a question in the Rural Area about building a house and dared asked about my sanity. I'm really wondering about my sanity! :cool:
:cool:
BTW, I did not get out on the property on Monday to do our regen/nonregen FEL cycle time test.
I should be out this weekend.
Later....
Dan KnowsHisLeftFromRightJustNotWhatTheyDo McCarty
<P ID="edit"><FONT SIZE=-1>Edited by dmccarty on 1/2/01 11:20 AM.</FONT></P>
   / 4 in 1 bucket tip #76
Hey, now you've changed and got it; right dumps, left curls./w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif Maybe those green tractors do work right./w3tcompact/icons/wink.gif
I have to throw a rock now and then to tell my right hand from the left, too./w3tcompact/icons/wink.gif
Bird
   / 4 in 1 bucket tip #77
Dan,
From page 15-1 in JD manual (430 and 460 loaders):
"OPERATING CONTROL LEVERS -
Move lever(A) forward to lower loader, and rearward to raise.
Move lever toward operator (left) to roll-back bucket, and away (right) to dump.
Move lever to extreme right for faster bucket dump(I assume this would be with REGEN "unlocked").
I hope to rig my 4in1 to "close" with a left/rollback motion, and "open" with the right/dump motion.
This seems "intuitive' (and easy to remember) to me, because when you pick-up(gather in your arms) or grab(close your fingers around) something, the "motion (of your arms or fingers is "towards" your body...i.e., a "left" motion of the joystick.
Makes sense to me... what do you think?
Larry
   / 4 in 1 bucket tip #78
Dan,
Re.; [[BTW, I did not get out on the property on Monday to do our regen/nonregen FEL cycle time test.]]
Remember that the regen(5.32 sec.) and non-regen (13.04 sec) dump-times I got at the dealer were at "idle" (however that may have been set... I didn't note the rpm-asked him later!).
A JD brochure gives the 460 loader dump-time as 2.2 seconds... no rpm given. The signifigant issue seems to be that, regardless of rpm, the non-regenerative time should be SLOWER than the regen time... if in fact the regenerative "assist" is being locked out. This is what we want for our 4in1 bucket operation, if I understand Mark correctly.
Larry
   / 4 in 1 bucket tip #79
Maybe we should be timing the "roll-back", instead of the dump, if we want to know if the 4in1 jaws will close slower(stronger), in which case it will be the "towards the body"/left joystick-motion that will be the issue.
Seems to me the REGEN-lockout should take care of it in either case,... but I'm too hydraulically-challenged to be confident.
What does anybody think?
Larry
   / 4 in 1 bucket tip #80
All rollback circuits are non-regenerative (not nearly enough force is generated by a regenerative one for the necessary breakout force), so the closing force (if you use the rollback circuit to close the 4-in-1 bucket) will always be whatever is generated by the pressure of the pump and the size of the cylinders on the bucket. So, the speed/force tradeoff issue isn't (an issue, that is).
The other thing to keep in mind is that it's so inconvenient to use the 4-in-1 bucket if it's plumbed to close using the dump circuit that it's a royal pain trying to get anything done. In order to pick up anything, particularly loose material, you have to roll the bucket back as you clamp it. So picture this scenario (with the bucket plumbed "backwards", i.e. close using the dump circuit): Drop the bucket into a pile of whatever. Now, using the following abbreviations:
RB - Roll Back
BC - Bucket Close
JL - Joystick Left (Rollback Position)
JR - Joystick Right (Dump Position)
JC - Joystick Centered (Neutral Position)
TD - Thumb button Down
TU - Thumb button Up
, this is what you have to do: [1]TD, JR (BC), JC, TU, JL (RB), JC, go back to [1] to start the whole process all over again, ad infitum, ad nauseum. (Try it with your hand, using a pencil or something to get an idea for how irritating doing this about 10 times in a row can be, because that's what you'll be doing to pick up something.)
Now compare that with the process if the bucket is plumbed correctly (i.e. the roll back circuit closes the bucket): [1]TD, JL (BC), [2]TU (RB), TD (BC), go back to [2] to repeat the process. Now try this with your imaginary joystick. As you can see, all you have to do while you're actually picking up the material is depress and release the thumb switch. No comparison.
MarkC
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2021 Caterpillar 308 Midi Excavator (A55973)
2021 Caterpillar...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
EPPS Powerhouse Pressure Washer (A55973)
EPPS Powerhouse...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
