4 in 1 bucket blowing crush washers
   / 4 in 1 bucket blowing crush washers #1
jamehadd
Mahindra 4035
Have a Mahindra loader with WR Long 3rd function/ 4in1 bucket. When fully closed or full open tractor will blow the crush washer on banjo bolt at diverter block. Works fine until you completely close bucket. WR Long valve is shifting.
   / 4 in 1 bucket blowing crush washers #2
Sounds like your relief valve may be bad.
   / 4 in 1 bucket blowing crush washers #3
Ya, sounds like a symptom not a problem. Things are going to blow out at the weakest part if the relief valve isnt working or adjusted correctly. Washers are the best thing that could break. Hoses are more expensive. Pumps are a LOT more expensive.
   / 4 in 1 bucket blowing crush washers #4
What type of ports are in the diverter block? Are they designed to accept banjo fittings? My thoughts are used the wrong style fitting in this port not designed for banjo fitting.
2022 International CV515 Ambulance, VIN # 1HTKSSWK7NH675363 (A54865)
2022 International...
CASE 90XT SKID STEER (A52705)
CASE 90XT SKID...
2021 Ram ProMaster City Van (A55788)
2021 Ram ProMaster...
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
2018 Ford Transit 350HD Handicapped Van (A53422)
2018 Ford Transit...
2016 Nissan Pathfinder SUV (A53424)
2016 Nissan...
