4 in 1 bucket blowing crush washers
   / 4 in 1 bucket blowing crush washers #1
jamehadd
Mahindra 4035
Have a Mahindra loader with WR Long 3rd function/ 4in1 bucket. When fully closed or full open tractor will blow the crush washer on banjo bolt at diverter block. Works fine until you completely close bucket. WR Long valve is shifting.
   / 4 in 1 bucket blowing crush washers #2
Sounds like your relief valve may be bad.
   / 4 in 1 bucket blowing crush washers #3
Ya, sounds like a symptom not a problem. Things are going to blow out at the weakest part if the relief valve isnt working or adjusted correctly. Washers are the best thing that could break. Hoses are more expensive. Pumps are a LOT more expensive.
   / 4 in 1 bucket blowing crush washers #4
What type of ports are in the diverter block? Are they designed to accept banjo fittings? My thoughts are used the wrong style fitting in this port not designed for banjo fitting.
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2010 Astec Underground RT660 4WD Trencher Backhoe (A55787)
2010 Astec...
Caterpillar 420F2 IT (A53314)
Caterpillar 420F2...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A54757)
UNUSED RAYSKY...
