4 hrs in new tractor...fluid leak
/ 4 hrs in new tractor...fluid leak #1
Bfitzgerald3
Harbor springs, mich
Kubota Mx5100
Im new to tractors and have a new kubota mx5100. Works like a charm...except...
Ive been finding small areas of pinkish drips in the snow after blowing but cant find the source. I havent seen/felt any obvious oily spots on the tractor and never find any spots where im parked. I think the leak is from the left half of the beast.
Thanks for your help!
/ 4 hrs in new tractor...fluid leak #2
If its new take it to the dealer.
I would if it were easy... 100 miles and i dont have a trailer. I'm hopng it's a matter of tightening something.
/ 4 hrs in new tractor...fluid leak #4
It might just be blowing it out the breather. It is new and probably filled to max. find the breather for the hydraulics' and look for signs of a little blow out.
/ 4 hrs in new tractor...fluid leak #5
Any chance its red antifreeze?
Do you run off road diesel or ULSD, you can sniff or taste the fluid to.see what it is
/ 4 hrs in new tractor...fluid leak #6
Pink in color tells me that its off road fuel. Check to see if some fuel was spilled when the tank was filled (running down the side of the tank). Also look to see if the fuel filter is tight. I had a fuel return line rupture on me one time when plowing snow and had pink snow everywhere. My .02 cents.
/ 4 hrs in new tractor...fluid leak #7
Could be lots of things on a brand new machine,as stated a simple over fill.I would place a piece of cardboard under the machine over nite and try to locate the problem area for starters.
/ 4 hrs in new tractor...fluid leak #8
All of the above. Mine started leaking antifreeze at about sixty hours. Come to find out if you actually read the owners manual and the break in section it tells you to tighten all the radiator hoses at fifty hours. A couple of turns on four clamps and problem solved. I hope yours is as simple.
/ 4 hrs in new tractor...fluid leak #9
I dunno, red or Pink?.. off road diesel is red, but pump diesel is green, the hydraulic fluid for the rest of the tractor is more or less clear to maybe a little yellowish.. the Kubota antifreeze is green. I cant think of any pink fluid in the tractor. Are you using off road diesel? if not, I don't think it is the tractor.. sounds like an automatic transmission car or truck.
James K0UA
It's definitely from the tractor...the fluid has shown up on snow that has never had a car drive over it. As for fuel, i'm not sure what's in it. The tank came full and i have yet to refuel. It may be pink, or perhaps red tha looks pink in the snow. The hyd fluid is yellowish...very different looking.
It sounds like a fuel issue to me, from wha i've heard. Work will get in the way of tractor tme tomorrow...hopefully i can dive into this in more detail on Friday.
I obviously hate that somethingis leaking, but we're talking drops here and there... I dont think this is a fatal leak...yet!
/ 4 hrs in new tractor...fluid leak #11
can you take a straw and get a bit of fuel out of the tank ? might be a place to start
/ 4 hrs in new tractor...fluid leak #12
Look at your fuel filter on the side of the engine.. you should be able to tell even looking thru the plastic cup if it has a reddish tinge or a greenish tinge. Often dealerships will have off road fuel, and fill your first tank with red.. I have used green ever since. So if it is from the tractor, it has to be fuel. Unless it is red grease falling off of the loader joints.. Look at the loader pins and see what color the grease on them is.. It falls off all the time. Mostly with dirt on it though.. I dunno if it would show as a drop in the snow or not..its probably fuel.
James K0UA
Diesel is just the right color. Thought it might be the relief tube from the tank, but it terminated above parts that look/feel pristime. Fuel filter feels mint clean too. Will rubber band papertowel over each and clear the drive...likewise. Lines from tank seem clean too. Before i do that, are there other places that are likely contenders for leaks?
Also, have called the dealer... Showing willngness to show up with tools to fix on location if necessary. Gotta love good service.
/ 4 hrs in new tractor...fluid leak #15
:thumbsup: I agree, nothing like good service. Two years ago, I bought the backhoe from my dealer. About 30 minutes using it, fluid started dripping out of the bottom. I took off the covers and could see the valve was leaking.
I called the dealer and he showed up the next day (80 miles) with a new backhoe on the truck. As it turned out, there is a fitting on the bottom of the valve to allow for expansion, that was loose. We couldn't see the fitting until the valve was removed. Good service is worth a lot. Last month I bought another new tractor from him.
/ 4 hrs in new tractor...fluid leak #17
I had a leak and traced it to the coolant hoses. I had to tighten them up a couple times before they got sealed good.
2023 CATERPILLAR 262D3 SKID STEER (A60429)
2023 CATERPILLAR...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
SKID STEER LAND LEVELER (A60430)
SKID STEER LAND...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
2020 DRAGON ESP...
