Oil & Fuel 4 cylinder vs. 3 cylinder diesel
   / 4 cylinder vs. 3 cylinder diesel #21
I also have a 3 cylinder 2400A backhoe. I beleive it is the same tractor as your 454d. This is a powerfull good running ,working 3 cylinder.
   / 4 cylinder vs. 3 cylinder diesel #22
FWIW................
My observations are from the industrial engines we use here at work to build construction equipment. In the 48-50hp range we prefer the 4 cylinders to the 3 cylinders because they are quiter and smoother. The John Deere 3029D engine that we used to use was not balanced and would vibrate your eye teeth out. The Yanmar 4NTE8FT and the John Deere 4024T engines are smooth, quite and a pleasure to operate.
TBAR
   / 4 cylinder vs. 3 cylinder diesel #24
<font color="green">My problem as a first time diesel owner is to know how smooth the engine should run. I have a John Deere 2210 with a 3 cylinder engine and from my limited experience with diesels I have the impression it could or should be running smoother than it does.
On a 3 cylinder diesel engine would it be very evident in terms of engine smoothness if the engine were not running on all three?
What makes a diesel run rough other than while it is warming up?
Mike</font>
   / 4 cylinder vs. 3 cylinder diesel #25
Heck my 7.3 L V8 tells me right away if on of the injectors isn't up to specs. It idles rough if it's popping early and smokes at low altitude if an injector is spraying poorly. It's very dependent on all 8 cylinders running well.
   / 4 cylinder vs. 3 cylinder diesel #26
<font color="orange"> Maybe you need to try a Kubota </font>
You know, with lotsa ketchup, they really aren't that bad...
/forums/images/graemlins/tongue.gif
   / 4 cylinder vs. 3 cylinder diesel #27
Smoothness may depend on the number of cylinders and the configuration. In a well designed engine counter rotating shafts may be relied upon to counteract the vibration inherent in some configurations.
The in line four cylinder engine is not a balanced engine.
Egon
   / 4 cylinder vs. 3 cylinder diesel #28
Egon, what do you mean by that? I mentioned but never had a follow up regarding the 3 cylinder diesel. Do you know if each rod is 120 deg. off from each other. To use an analogy, is it like a 3 bladed prop? I would think of the inline 4 as a double row, 2 bladed prop. Rat.
   / 4 cylinder vs. 3 cylinder diesel #29
</font><font color="blue" class="small">( Smoothness may depend on the number of cylinders and the configuration. In a well designed engine counter rotating shafts may be relied upon to counteract the vibration inherent in some configurations.
Egon )</font>
In the industrial engine market some four cylinders have the balanced option. In our case we have used Ford, Cummins and Perkins engines with the option.
Some three cylinders have this option too. This might be how the Japanese have obtained such smooth running 3cyl engines in their tractors.
FWIW, we looked at the Kubota's but they wouldn't fit our machinery envelope.
TBAR
   / 4 cylinder vs. 3 cylinder diesel #30
Rat:
Just what I've read.
Inline 4= unbalance
Inline 6=balanced
boxer 4=balanced
90 degree v8= balanced
60 degree V6 = balanced
inline 3= ???
60 degree V twin harley = unbalanced
Egon
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2021 Troy-Bilt TB110 21in Push Mower (A55973)
2021 Troy-Bilt...
2015 Freightliner M2 106 4x4 Altec DM47B TR 47ft Digger Derrick Truck (A55973)
2015 Freightliner...
2018 John Deere 4066R (A53314)
2018 John Deere...
1999 FREIGHTLINER FLATBED (A58214)
1999 FREIGHTLINER...
