Chipper 4" chipper for scut
/ 4" chipper for scut #1
sqidget
Rhode Island
BX-24
Hi,
Does anyone here have a 4" or 4.5" pto driven chipper? I am trying to decide on which chipper to buy. I am considering a Wallenstein or a Bearcat. Both are available locally. My main question is for a SCUT (BX24). Does the wallenstein feed ok on a 540 rpm pto (manual hopper)? All the others have belts to increase speed and thus increase momentum, only they use smaller flywheels. I only have a 540 rpm pto. I want this chipper due to the top discharge and I looked at both and visibly looks better built.
The bearcat is a manual feed(no shredder) and bottom discharge.
I have also considered the DR chipper because my father has one with a 13 hp engine and it took everything I fed it, but any foliage on the wood will clog the discharge(bottom). I need this before spring so I am looking for any feedback for these.
Thanks, Dave
/ 4" chipper for scut #2
Have you checked out the Jinma chipper discussion? I have one. It has served me well. It takes some setup,but it will do a great job. I feel it is the most machine for your dollar. I wouldn't consider it for a heavy use or commercial use, but for a homeowner it is worth a look anyway.
No,
Due to the fact that there is no local dealer to harass when it breaks or does not work as claimed, also no due to the fact of weight, jinma chipper weighs 800# and is HUGE. I only have a Kubota BX whose 3pt capacity is 680#.
/ 4" chipper for scut #4
I purchased a Wallenstein last August and have been very happy with it. It was ready to go with no setup and handles everything up to 4", although to me anything over 3" is fire wood.
When I talked to the salesman I thought I wanted a hydraulic feed, but he made a deal with me - take it home as is and if I didn't like it he would add the hydraulic and not charge me any setup fee. I took it home and found he was correct - the design seems to feed most things in and I saved myself $$$$.
The Jinma is less expensive by a few hundred dollars and there are others out there that are several thousand more. For my situation the Wallenstein has been a good solution for my needs.
The dealer where I bought it ships everywhere, so in case you want to contact them, here is a link:
Iowa Farm Equipment
Good luck
/ 4" chipper for scut #6
I have a Bush Hog, which is really a Goosen. Run it on 21 pto hp. Does up to 5" branch. But what I liked best is that the separate shredder takes up to 1.25" branches. This is a real time saver, as you can put most of the brush right in the shredder. It weighs ~600 lbs without blower. Look for used, you can really save a bundle.
/ 4" chipper for scut #7
I would have to reccomend the walenstein. I have the 42 and it is awesome. It has the double hydrolic feed rollers, and it pulls in surprizingly well. I don't have to limb most things out anymore.
Daryle.
/ 4" chipper for scut #8
BX 42 - 3 Point Hitch Mounted
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Standard Features[/FONT]Four angle mounted hardened tool steel knives are designed to draw material into cutting chamber.Reversible stationary and rotor knives double time between sharpenings.Discharge hood rotates 360 degrees.
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Engine[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]PTO Driven[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Drive System[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]PTO with Shearbolt[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Chipper Capacity[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]4" Diameter[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Rotor Size[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]20" Diameter[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Feeding System[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Self Feeding or Hyd. Roller Feed[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Recommended PTO HP[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]16-40 HP[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Mounting System[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Category 1 - 3PH[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Dimensions[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]57"L x 54"W x 60"H[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Hopper Opening[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]18" x 18"[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Discharge Hood Rotation[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]360 Degrees[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Discharge Hood Height[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]60"[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Rated RPM[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]540 RPM[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Weight[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]400 LB[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Engine Starting System[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]---[/FONT]
400 lbs that far back on the 3 pt may require front weights or the FEL on with some weight. When I use my aerator it makes the front lite. I think you will be pushing the engine on some of the bigger stuff depending on the wood and how hard it is with only 17.7 HP at the PTO. You may have to go slow and not feed it as quickly as you want to.
/ 4" chipper for scut #9
There have been quite a few threads on this -- Jinma is by far the least expensive, and Wallenstein and Bearcat are also well rated, and there was a recent thread on the DR chipper for our class of machine.
I have the Bearcat 70554 on my BX2350 - a bottom discharge model with shredder. At 450 pounds it is heavy back there, but I always have the FEL attached so I can carry my chainsaw around :). As Gittyup says I find the shredder really worthwhile, but it's a scary thing to use when it yanks the branches out of your hand.
As for the chipper, it will bog the BX's engine down on larger stuff. If I've got a bigger (4-5") pieces I cut it into 4-5 foot sections and have no problems. Mine is manual feed so also have some control there. Mostly I use mine for smaller cleanups and have found if I keep the blades sharp the manual feed pulls stuff in on its own quite well. Smaller 3" stuff it will consume all day long without a problem. There's been discussion in the past that especially for our smaller tractors a larger flywheel weight helps balancing out our smaller PTO hp.
/ 4" chipper for scut #10
I also have the Bearcat 70554. Nice piece of equipment. The 125lb flywheel distinguishes it from the smaller Mac and DR chippers and really does make a difference with the bigger material. Sometimes I wish I'd gotten the top blower discharge because it can fill up the space beneath the chipper pretty quickly. I've solved that somewhat by having a long folded tarp under the chipper discharge that I just pull out when it gets piled too high and keep going. I'd recommend the chipper as a good value too, a bit more money than the smaller DR and Mac but much less money than the bigger hydraulic feed models.
Thanks for the replies.
one more question for you guys with the wallenstein.
How does it self feed older dry wood, say 1-2" dia.blueberry?
I only have 1 wooded acre that I want to partially clear and then use for maintence. I cant afford a hyd feed machine.
Thanks again for your input.
Well I bought the wallenstein BX42 with manual hopper today. I am quite happy with it. I managed to stall the tractor with a 4"to5" piece of oak. Once it got below 3.5" the engine rarely slowed. It self fed surprisingly well considering some of the wood was dry or standing dead. The only drawback is the lower mounting pins are to low for the BX. I will put two 4x4 psi treated on the bottoms of the skids and all is well!
/ 4" chipper for scut #13
Glad to hear that you are happy with the Wallenstein. I'm happy to share my own experience, but never want to lead someone astray.
You mention that the engine stalled on a 4" to 5" piece of oak. In my world, anything that size if firewood, but I'm guessing you were testing the capacity of the chipper.
I believe I understand what you are saying about the pins being too low for the chipper. In my case, I kept the pallet that it came on and that makes it perfect to line up with my tractor.
Good luck and make lots of chips (smile).
/ 4" chipper for scut #14
I have not had any problem hooking up to my M-F 2300 right off the truck, however I made a frame with casters on each corner to allow movement in any direction. Sure beats dragging the chipper around in the garage when I have to move it.
I am sure you will be happy with it, I would reccomend to anyone, Good luck.
/ 4" chipper for scut #15
Sqidget,
The biggest issue with the BX24 will be the weight of the chipper and what kind of ground you'll be moving over. Sure tossing an 800lb chipper on a 5000lb tractor is fine but the BX weighs 1500lbs to 2000lbs.
I have a Salsco 600 that I run on a B2910. It weighs about 400lbs and even at 400lbs you know it's back there when moving on uneven ground. Chippers end up pushing a lot of weight pretty far back from the rear axles of the tractor.
Any of the Jimma/china chippers While they work fine will be dangerously heavy on that machine.
Compact size is nice if you can get what you need. I find the tractor with the smallish unit I have can be easily maneuvered through the woods to get to palces I want to use it.
Regards,
Chris
(APPROX.18), 40"X159" INSULATED PANELS (A62131)
(APPROX.18)...
JOHN DEERE 4044M TRACTOR (A62130)
JOHN DEERE 4044M...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 1HTMMAAL0DH414751 (A61165)
INOP/NON-RUNNING...
Detroit Diesel Auxiliary Hydraulic Power Plant Generator (A61568)
Detroit Diesel...
2012 Komatsu PC360LC-10 (A61166)
2012 Komatsu...
2013 FREIGHTLINER Cascadia (A63118)
2013 FREIGHTLINER...
