4' brush hog on a TU155?
   / 4' brush hog on a TU155? #1
Chris_in_Oz
South of Perth, Western Australia
Iseki TU155 Landhope
4\' brush hog on a TU155?
Hi guys,
Do you think my TU155 would pull a 4' hog?
Fairly flat land, about 2.5 acres to keep under control.
I've been offered one and don't want to buy it if it isn't going to work ok. It has a slip clutch istalled on it already.
Cheers,
Chris.
Hi guys,
Cheers,
Chris.
   / 4' brush hog on a TU155? #3
Re: 4\' brush hog on a TU155?
I'm not real familiar with the TU155, but I assume that it's about the same power, size, etc. as my TX1500 (15 hp PTO).
I run a 4' rotary cutter behind my TX1500 and it does fine with it. When I get into weeds that are too tall (like 3 feet) I have to gear down, but it still cuts pretty well.
   / 4' brush hog on a TU155? #4
   / 4' brush hog on a TU155? #5
Again, I'm not too familiar with that particular model but a buddy has a TU180 and he pulls a 4 foot hog with no problems. Every now and again it belches black smoke when he gets into the 4'-5' stuff. Other than that he says it is no problem.
YMMV.
   / 4' brush hog on a TU155? #6
YMMV.
Iplayfarmer - great name!
Yes, the TU155 has the Mitsubishi K3C engine (900cc, 3cyl, 18.5 hp / 2700 rpm) and the sticker on the tractor says 15.5PS / 2500 rpm, which equates to about 15.2HP.
Do I need an overrun clutch?
Cheers,
Chris.
Cheers,
Chris.
   / 4' brush hog on a TU155? #9
I don't know if that model needs the over running clutch.
If you don't have it, consider weights on the front end. I have 4 x 45lbs on my TS1610. In some cases I think that is still not enough for my 4' bush hog. I may try more weight.
I don't know the weight of a TU155. But I expect it is similar to the older TS1610.
   / 4' brush hog on a TU155? #10
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
