3x20 3520 eHydro Problem No Reverse No Error Codes Forward works Fine Please Help!
   / 3x20 3520 eHydro Problem No Reverse No Error Codes Forward works Fine Please Help! #11
Cobra, I hope you are still there. I have a 2011 3520 w Ehydro . It has a little over 800 hrs. without warning when I got on it to mow some grass it would only go backward. The forward pedal would throw error code 14. When I switch the plugs under the peddles the forward pedal works reverse direction fine. You mention you put 12 volts directly to coil to move the tractor. Which pins was that? Was it just 12 volt dc from battery. Note: I already tried the Diagnostic 13 recalibrate and managed to get it out of calibration. Now when I enter the code LLLRLR to get back in, but it simply tells me "Cal off". I can toggle it to "Cal on" with the blinker, but cant get into actual pedal recalibrate. Tractor now cranks but will not move either way due to lack of cal now. I really want to know if the coil will move it before I drop off at John Deere. Im afraid they will jus split the tractor and change the proportional valve first... Please help if you can?
   / 3x20 3520 eHydro Problem No Reverse No Error Codes Forward works Fine Please Help! #12
I meant to say Cobra Tom
   / 3x20 3520 eHydro Problem No Reverse No Error Codes Forward works Fine Please Help! #13
- 2007 JD 3520 eHydro 649 hours. NO FORWARD or REVERSE... 3 point hitch, power steering, and loader all work fine.
- Dealership just completed 4.5 hours of labor attempting to determine problem. Came to conclusion that they were not sure.
- John Deere corporate recommended local tech split tractor to try a couple more things ($$$) or just replace eHydro transmission for over $8,000.
- Looked like some prior discussion of solenoids and valves that require tractor split to check/service.
- Any helpful information would be much appreciated!
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2025 SDLanch SDLD25 Mini Crawler Dumper (A55851)
2025 SDLanch...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2019 Autocar ACX Xpeditor T/A EZ-Pack 40 Yard Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2017 Freightliner 114SD Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55852)
2017 Freightliner...
