3x20 300CX hydraulic operating pressure
   / 3x20 300CX hydraulic operating pressure #1
Nitro-Fish
VA
JD 3320
Well it's that time of year again, just replenished the stock of wood pellets for the season (unloaded with the 3320 of course) as I've mentioned before the 3320 will move them, but not quite with authority. I am wondering what the suggested operating pressures are for the 3x20/300CX loader set-up. I shimmed the relief valve on my 790 & it helped a great deal, if I can do something similar on the 3320, I believe I will then be able to handle the pallets of pellets a bit easier. I checked the pressure and presently it is set to start by-passing at 2400 PSI; I assume this is the lower end of the operating range. I've read that it is a matter of adjusting the pressure relief on the 3320's & not a matter of shimming as on the 790, however, I am trying to find out if anyone has bumped the pressure up on the 3x20's & what they have been increased to.
   / 3x20 300CX hydraulic operating pressure #3
Before you bump your system pressure, I would recommend additional rear ballast.
   / 3x20 300CX hydraulic operating pressure #4
No "window" is stated in the service manual, just 2500 psi. I have considered bumping mine up, but first I want to take my guage to work and see how accurate it is. Mostly I want to bump it up because more is always better, right?
And as kjung says, add ballast.
   / 3x20 300CX hydraulic operating pressure #5
I increased my JD 3520 and JD 4520 both to 2800 psi. Been that way for about 3 years. No issues. It is noticeable on the FEL capacity. My starting psi was 2450 for both.
   / 3x20 300CX hydraulic operating pressure #6
Hmm... if my math is correct - that's a 14% increase in operating pressure.
And everybody "seals" OK with that? :D
I'd like to bump my 110 up a bit, too.
AKfish
   / 3x20 300CX hydraulic operating pressure #8
AKfish
Oh, I just figured everybody knew these pressure tweaks would accelerate wear and promote failure. I wonder if they set their water heaters to 200 degrees? ;-)
   / 3x20 300CX hydraulic operating pressure #9
Need to remember, the amount of time the pressure is reaching the maximum is actually quite rare in most circumstances. Most lifts with FEL or 3 pt are way below max capacity. My FEL maybe lifting an extra 250-300 lbs at the increased psi. Cylinders are usually designed to tolerate pressure much more than the mild bump we are giving the overall psi increase. I wouldn't be surprised if cylinders are rated for 3000 psi. Theoretically, there is probably increased wear in the pump but in practical use it is a nonissue. Should we all decrease the psi to decrease the wear?
Lots of prior skid steers were 3000 psi. Now many are 3300 psi and still use the same attachments, cylinders and hydraulic motors. My old attachments still work as before. I use some skid steer attachments on my compact wheel loader and that psi is 3600. No issues-yet!
   / 3x20 300CX hydraulic operating pressure #10
I never mentioned decreasing pressure. On the other hand, why accelerate the wear by adding pressure that is not really NEEDED. 5% sure. 14% is too much. I see more evidence of side loading on cylinders used on "bumped" systems. Also, you are talking about different class of equipment. These fellas are bumping a little compact. They aren't built as heavy. I always set systems to the high end of spec.
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2018 Chevrolet Equinox AWD SUV (A53424)
2018 Chevrolet...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
UNUSED LANDHONOR LDH-HT380 STAND ON SKID STEER (A54756)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
