3rd unction valve or diverter valve?
   / 3rd unction valve or diverter valve? #1
MD09
King George VA
Hew Holland TC34DA
So the question for the experts here is ,
I am looking, to install either a 3rd function valve or a diverter valve for the loader. Third function is expensive but allows all three function at one time. Diverter valve is cheaper but cannot be operated with dump/curl function.
So what are to pros and cons of each from those who know.
Thanks
   / 3rd unction valve or diverter valve? #2
I installed both on my tractor. I found that I'm generally not using my grapple (reason I installed 3rd function valve in the first place) when I'm using an implement in the back. A diverter valve simply allows me to go back and forth without taking fittings apart. I do admit though if I had it all to do over I probably would have just ordered the tractor with a couple more hydraulic ports.
   / 3rd unction valve or diverter valve? #3
I have and use the 3rd function valve for the HLA 2000 snow plow on my fel, the rear remotes are used for my LA2674 3 point snow blower chute control. This way each can run in-dependably of each other at the same time without having to switch a diverter valve back and forth.
DevilDog
   / 3rd unction valve or diverter valve? #4
Thanks
Here is my :2cents: for whatever that may actually be worth these days. And yes I am well aware that many if not most TBNers seem to prefer the true 3rd function, other than bragging rights of being able to do 3 functions at once, big deal. In reality, for most applications it is not. AGAIN just my :2cents:
True 3rd function allows you to operate 3 loader functions at a single time. Now what no one talks about is that the joystick has to be just right for that to actually happen, otherwise the 3rd function simply does not work.
Next thing, what tractor do you have and what is the pumps GPM? Smaller tractors often will work ok, because the cylinders are so much smaller, so the speed isn't bad. But move up in size and the cylinders seem to get bigger at a faster rate than the pumps, so things slow down.
The next "problem" in my mind with a true 3rd function is that you have no real control of the speed that the fluid flows to the cylinder. The valve is either open, or closed. Nothing in-between, no actual feathering of the control. You want-need to feather, you need to flip the switch off-on, off-on fast to try to get the desired result.
For plumbing, you have to get into the power beyond line. This can be or not a problem for some people.
With a diverter 3rd function, you typically reroute the curl function hoses through the diverter. You have 100% full control of the aux hyd function. You can not curl and operate the 3rd function at the same "exact" time. For some reason people think that there is time lost between changing those functions. The time lost in reality is miniscule.
(I seem to remember that it is around 1/16000th of a second?) so if that is going to slow your work down, better get a true 3rd function and have the issues that come with it.
Something else that is a misunderstanding, people seem to have gotten the idea that the control always has to go back to neutral before using the other function, this IS NOT TRUE, at least with the valves that I sell. You can operate these valves back and forth while the main control valve is in use. So in theory if you were good you could get the same results as operating 3 functions at once. But why?? :confused3:
Next thing that I have never been able to understand, but maybe it is just me. When I use my grapple, I like to clamp down on what I'm picking up before I raise and curl. Why would you want to raise at all and have stuff falling out before it is ever clamped down? Again, might just be me, I don't really use my grapple all that much.
Something else that needs to be mentioned is that if you have a loader control that has a 3 position curl with the regeneration mode in the dump side, the diverters are not going to operate properly and a true 3rd function is the best way to go. These type controls are std on the economy Kubota L and MX models from what I have seen. Also currently on some of the newer JD models.
As far as cost, you are just looking in the wrong places. I sell both kits complete, all hoses, fittings etc. for the same cost, $715 delivered for anything under 12GPM. +Sales tax if you're in California.
Hope this helps you and others at least some. ;)
   / 3rd unction valve or diverter valve? #5
If you only use partial lever on the FEL, you can then use the 3rd function valve.
The 3rd function valve speed of operation will be dependent on the GPM flowing through the 3rd function valve.
If you use full pump flow on the FEL valve, no fluid will flow to the 3rd function valve until you finish up using the FEL operation. If I remember correctly, an exception to this is the series flow FEL valve.
3rd function valve.
12 VDC 10 GPM OC DA SOLENOID VALVE
Diverter valve.
12 VDC 13.2 GPM SAE 8 SOLENOID DOUBLE SELECTOR VALVE
   / 3rd unction valve or diverter valve? #6
Pretty much what Brian said, I have a third function on my L5740 and really like it, but for the difference in price and smoother control, I will be going with a diverter kit on our M8540.
   / 3rd unction valve or diverter valve? #7
Another diverter fan here, for all the reasons Brian so eloquently stated.
   / 3rd unction valve or diverter valve? #8
Me too.
You could mount a manual converter valve with a lever up on the loader frame where you could reach it for easy switching between the 2 circuits.1/2" NPT 20 GPM DOUBLE SELECTOR VALVE
I just got 2 of these and they can be mounted in any direction and the "handle" can be mounted in 3 positions.
   / 3rd unction valve or diverter valve? #9
I had a diverter valve, didn't like it. Went to a 3rd function much better. Cost is very similar. I haven't yet, but intend to put the diverter valve on the back to split one of the rear remotes for TNT setup, which will free up a remote valve.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
