3rd Selective Control valve for 4310
   / 3rd Selective Control valve for 4310
Right now, I have a homemade log splitter to use with the
3rd SCV. Later I plan on adapting my 6 foot rear blade so I
can angle the blade left or right without leaving the seat.
As for the still dreaming about it stage, I would like to make
a grapple log skidder for the 3 point hitch.
   / 3rd Selective Control valve for 4310 #12
bringing this back from the dead. I just bought a 4310 and was looking at the third scv. Looks like the level comes up in front of the lift arm lever lock. did you have to cut a hole for that then and is it marked underneath? thanks
   / 3rd Selective Control valve for 4310 #13
I sort of doubt that you will get a response from Perry. His last post on TBN was April of 2013.
   / 3rd Selective Control valve for 4310 #14
csnow
Others with the 4310 or experience will likely give you some info, if Perry doesn't. Maybe a PM to Perry will help too.
Sounds to be some different than the 3rd SCV I added to my 4300.
There were good directions in the kit, if that is still available through Deere
   / 3rd Selective Control valve for 4310 #15
csnow
I did a little more research and found out you cut the original panel which has markings on the bottom. Now I'm trying to find a good place to get a tech manual for the 4310. Thanks for the responses
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
