3rd SCV on Deere 3720 - flow issues
   / 3rd SCV on Deere 3720 - flow issues #1
nhemmer
Newberg
John Deers 3720 Cab tractor with 300CX FEL
I thought the point of an SCV was if multiple spools were activated simultaneously the valve balances the pressure between all 3 spools????
When I run my Clemens weeder with the 3rd SCV spool on my Deere 3720 I can't get the 1st SCV spool to raise the weeder (normally for raising the FEL) but with the Clemens I have a double acting S5 lift column from Clemens that I have attached to the quick connects out front.
Is there something wrong with my SCV or do I not understand the function of the SCV. I am an engineer but hydraulics are not my specialty and farming is a new venture. Can someone that understands Deere SCV functions help me out?
PS. the 3rd SCV is plumbed to a flow control - something the Clemens needs to function optimally. If I dial back the flow on this I can get the 1st valve to work but again I thought the point of the SCV was to allow all functions simultaneously. eg. if I had a grapple on my FEL i would need them all to work together.
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
3650 (A47477)
3650 (A47477)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
