3rd function valve
/ 3rd function valve #1
sparkyjc
Does anyone have any suggestions on where to mount a 3rd function valve for bucket grapple on a kubota L3430?
/ 3rd function valve #2
Are you buying a kit from a manufacturer or are you sourcing parts yourself? Is the valve an electric solenoid type or manual lever type?
I need more info to give an intelligent answer.
I am sourcing parts myself. Probably at Surplus Center. It will be a electric solenoid valve.
/ 3rd function valve #4
Make a mounting bracket out of 3" or 4" wide x 1/4" flat stock just a little bigger than the size of the valve and it's DO3 subplate. Drill 2 holes in the flat stock to match those just below the loader valve on the right loader tower. Mount the valve there. That is where WR Long valves mount. You will need a short hose section to go from the loader valve PB port to the DO3 subplate inlet. The hose that connected to the loader valve PB connects to the DO3 subplate's outlet.
