3rd function valve, do you get?
/ 3rd function valve, do you get? #1
threeman
Do you get the valve plumbed out to the loader? Is that a seperate part? Would you recommend that, for sure I would think? Anyone know?
/ 3rd function valve, do you get? #2
If you are going new tractor, get it plumbed to the torsion tube support with a bulkhead quick-attach valve plate.
If after-market, the W.R. Long electric over hydro with their bulkhead quick-attach valve plate as well.
/ 3rd function valve, do you get? #3
I had a Fasse valve fitted to a loader on an L4310 to operate a grapple rake (by W.R. Long). It provides for a button on the joystick which is easy to use.
I do note that with the additional hydraulic lines, the loader curl circuit doesn't operate on cold winter days for a few minutes - probably until the fluid warms up?
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
7061CFL (A64553)
7061CFL (A64553)
2021 INTERNATIONAL LT625 8X6 TRI-AXLE TRUCK TRACTOR (A67148)
2021 INTERNATIONAL...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
