3rd Function for L45
   / 3rd Function for L45 #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
I recently traded my L39 for an L45. I had installed a Kubota 3rd function kit on my L39. I was lucky enough to find it on Ebay for ~$500. Now I am looking to install a kit on my L45. The Kubota kit is $885. The WR Long kit is $837 from Everything Attachments. It looks like the hydraulic flow is ~12 gpm.
Can I piece together a kit cheaper?
Valve
Handle/switch
Hoses
Fittings
ac
   / 3rd Function for L45 #2
I would think so. I did my L3010 for $275. I did not use and electric solenoid hydraulic valve w/ a switch in the loader lever though. I used a standard spool valve and had a separate control lever for the grapple valve.
http://www.tractorbynet.com/forums/.../262400-3rd-function-valve-2.html#post3062988
Hmm...I wonder how I could mount that. The L45 uses a cable driven FEL valve with the control lever mounted to the right of the operator. Not quite the same setup as the removable FEL and loader valve you have.
I had the electric over hydraulic on my L39...I'm not sure I would want a 2nd lever.
ac
   / 3rd Function for L45 #4
Do you have to have the true 3rd function? Diverter valves are less $$$ and easier to install.
   / 3rd Function for L45 #6
Can I run a hydraulic auger off of a diverter?
ac
Yes sir, just need to be sure to have a big enough flow diverter, no different than you need to be sure to have a big enough 3rd function valve and you would not use a momentary switch, but a maintained type switch. Same applies to both types of valves.
I think I want to stick with a true 3rd function like I had on my L39. The more I think about it, the more I liked the way it worked.
Any suggestions for the electronic solenoid valve? I think it needs to be double-acting with an open center.
Do I need 1/2" or 3/8" lines?
ac
   / 3rd Function for L45 #8
I would use the sizes you have on the tractor now. My L3010 had 3/8" hoses and 1/2" (SAE 8) fittings. So that is what I used. My flow is only 6.8 gpm. I used an 8 gpm valve that was on special at Surplus Center.
   / 3rd Function for L45 #9
ac
I would use 1/2" hose for the 3 main lines and 3/8" for your 2 work lines. ;)
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2017 KENWORTH T680 SLEEPER TRUCK (A54313)
2017 KENWORTH T680...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
