3R series rear remotes
   / 3R series rear remotes #1
EuroYanmar
Somewhere
Tractormatic
Good morning,
Here in EEC the JD 3R series are delivered standard with one rear remote only.
One more can be installed but the dealer told me it will be "electro hydraulic" .
I understand it will use a solenoid valve.
Is the situation the same in US ?
Have you got two true rear remotes or one true and one "electro hydraulic" ?
Thanks for your help,
Phil
   / 3R series rear remotes #2
I believe if your tractor has a cab, then that is your only option.
Open station tractors can have a 2 spool manual SCV.
Thanks for your answer Chevy.
The tractor is a rops tractor.
Onequestion : if you have got two spool manual SCV, how do you command them ?
Thought the front end loader joystick ?
Phil
   / 3R series rear remotes #4
The valve mounts to the right ROPS post, just above the right fender.
It has a lever for each spool. The part number here is LVB26035.
Chevy,
Your answer is clear like crystal.
Thanks a lot for having posted this picture and part number.
Phil
   / 3R series rear remotes #6
How tough is the above to install on your own? Thanks!
   / 3R series rear remotes #7
I have the same setup on my 4720 open station, and the install wouldn't be too difficult.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2017 Chevrolet Express Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A52748)
2016 RAM 5500...
