3pth Log Splitter
/ 3pth Log Splitter #1
Tul01
Manitoba, Canada
2015 John Deere 5115M, 1928 and 1945 hand start John Deere D's,
Hi guys I built a log splitter to run on the back of our tractor this past winter. I used a log splitter valve with kick off, I think this was the one, I can't find numbers any more
Directional Control Valve with Kick-Off | Princess Auto
When I built it and tested it, worked perfect, kicking off on return. This fall as soon as I started it up, it wouldn't kick off, and when the valve hit either end it would cause the tractor hydraulics to go into relief and squeal. I split a few cords just being careful. 2 questions:
1) Why doesn't the tractor go into relief when I stop it at any other position than the ends of the cylinder (and is this hard on the tractor) and
2) Should I pull it apart and see if there's a bit of grit in it causing it to not kickoff properly or is there too much flow or something now that I was revving it a bit, I think I may have tested it only at idle.
/ 3pth Log Splitter #2
Your kickoff pressure is adjustable.
Install a hyd gauge and test it.
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
YALE FORKLIFT (A63291)
