3pth Log Splitter
/ 3pth Log Splitter #1
Tul01
Manitoba, Canada
2015 John Deere 5115M, 1928 and 1945 hand start John Deere D's,
Hi guys I built a log splitter to run on the back of our tractor this past winter. I used a log splitter valve with kick off, I think this was the one, I can't find numbers any more
Directional Control Valve with Kick-Off | Princess Auto
When I built it and tested it, worked perfect, kicking off on return. This fall as soon as I started it up, it wouldn't kick off, and when the valve hit either end it would cause the tractor hydraulics to go into relief and squeal. I split a few cords just being careful. 2 questions:
1) Why doesn't the tractor go into relief when I stop it at any other position than the ends of the cylinder (and is this hard on the tractor) and
2) Should I pull it apart and see if there's a bit of grit in it causing it to not kickoff properly or is there too much flow or something now that I was revving it a bit, I think I may have tested it only at idle.
/ 3pth Log Splitter #2
Your kickoff pressure is adjustable.
Install a hyd gauge and test it.
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
