3pt wood splitter modification question
/ 3pt wood splitter modification question #1
NPurdy1112
West Central Indiana
Kioti NX4510 HST
Hello all,
I have been using an old, over sided ram splitter that was given to me by the FIL. I would like to try and speed things up for my one man operation of wood processing. Running this thing off the rear remotes is time consuming and painfully slow.
Wondering how I can add an auto cycle valve, like something here; Prince hydraulic control valves LOW $$$$$ ?
If I plumb it up according to the instructions, how would the machine work? Would I have to bungee the handle by the tractor seat open and then use the new valve or is it more complicated than that? I do not fully understand hydraulic systems just yet.
View attachment AutoCycleParts (1).pdf
Thank you,
Nick
/ 3pt wood splitter modification question #2
If you want to speed things up, the best way to do it would be to add a separate reservoir and plumb it up to a PTO pump, like the ones made by Prince. That's the way my three point splitter is set up and it's pretty quick, even with a 5" cylinder. The auto cycle would be a good addition too, but it's not gonna change the ram speed. It'll just make it so you don't have to stand there the whole time. And yeah, I'm thinking that you'd just need to bungee the remote valve open. Is that what you do now?
/ 3pt wood splitter modification question #3
I'm not an expert on hydraulics but what the Rapid Extend Control Valve does is make it so you don't need a two stage pump on a small gas engine. It can't speed up hydraulic flow of your tractor. To do that you'll probably have to either convert it to a PTO powered pump to get more flow or swap out the hydraulic cylinder for a smaller one to reduce the amount of fluid needed. The problem then comes down to just how much do you spend on modifying what you have vs just buying a stand alone splitter (or 3pt). For me I ended up with a stand alone and I use my loader to lift large rounds up so I can just roll them onto the splitter.
Do you know how big the cylinder is? I'm sure someone here can tell you how many tons it develops. My stand alone is suppose to be 27 tons (but probably less) and has never had a problem splitting anything. How far does it extend? Most people use around 16" for their fireplaces. If the thing can extend 30" or more then you can help speed thing up by not letting it retract (if you don't already) all the way back between rounds.
motown: I agree, The time I would be saving is not having to stand by the tractor seat handle cycling the ram. I can "work" while the auto cycle valve does one stroke. I have not got a quote from Chris at Wolfe Ridge on the 3pt pto splitter yet. Was hoping by adding the auto cycle valve, it could buy me some time before biting the bullet on a brand new setup. I run the valve on the tractor back and forth now, there is none on the splitter. It just connects to the tractor rear remotes.
crazyal: The cylinder is large. I would have to go measure, but I am at work till 0700. It was re purposed by the FIL from a large dozer 30+ years ago.
/ 3pt wood splitter modification question #5
On my 3 point splitter that runs off the remotes, I put a valve on the splitter and then leave the one on the tractor open.
That way, I can just stand at the splitter to run it...
SR
SR
Thanks SR. I didnt know if the tractor valve needed modification or just having one open was enough. Thank you for the clarification.
/ 3pt wood splitter modification question #7
Have you been setting a piece of wood on the splitter and walking around to the tractor to hit the lever? In that case any valve would speed production time a lot. An auto cycle valve like you’ve got would speed it up more. A PTO pump of higher GPM would speed it up more.
Yes that has been my process this far. Time consuming. If I add a PTO pump then wouldn’t I need an external hydraulic fluid reservoir?
/ 3pt wood splitter modification question #9
Yes, and it would be an expensive process. Just adding a valve would increase production significantly.
Thank you. I will look for a valve to put on the splitter itself. Appreciate all of the information everyone.
Another question. Lets say i get a simple prince detent log splitter valve. Their diagram shows for an external reservoir system. With specific inlet and outlet ports. If i am using the rear remotes from the tractor and have to bungee the valve open by the seat, how would i plumb this and make it work?
/ 3pt wood splitter modification question #12
The valve should allow fluid to flow through it freely unless you hit the handle. So you’d bungee cord the tractor rear remote handle down. You’d put the tractor rear rear remote hoses on both ports on the valve.
4570: Thanks a bunch! Hopefully get to work on modernizing this splitter soon. Time for sleep.
EDIT: Fixed the issue
/ 3pt wood splitter modification question #15
A rapid extend Valve will speed up a 3pt wood splitter quit a bit. I upgraded mine with this valve from Prince som i have trues it.
2015 TEXAS PRIDE GOOSENECK (A63569)
2015 TEXAS PRIDE...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
18' Utility Trailer (A64047)
18' Utility...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
