3pt won't lift
/ 3pt won't lift #1
RussH
Hillsboro, Oregon
Kubota B7200DT
3pt won\'t lift
Hi I have a problem and I was hoping for some net wisdom. I went to use my B7200DT this morning and the 3pt will not lift at all. It worked fine yesterday brush hoging, and I did not change the 3pt dropping rate knob. The lever seems too loose with out the usual resistance to it but I could not see anything loose on the external linkage. The loader works so I know the hyd. pump is working. Anyone have any advice for me? I just got my new blades for my brush hog installed last night and now this.... :-(
Thanks,
Russ
/ 3pt won't lift #2
Re: 3pt won\'t lift
RussH, I don't know if this will help or not, but when I had a B7100, one day the 3-point wouldn't raise; scared the heck out of me. But I found that wiggling the lever on the loader just a bit made the 3-point work again. It seems the loader valve wasn't completely closing or centering, but was so close I hadn't noticed it. That happened two or three times in the 4.5 years I had that tractor. I'd just wiggle the joystick a little bit to get it centered and the 3-point would work right again.
Bird
/ 3pt won't lift #3
Re: 3pt won\'t lift
Russ,
On my B7100 I have a directional control valve located under the seat on the right hand side,does your B7200DT have one also?
If so check to see if the knob is wide open, for it doesn't take much to slow the flow of hydraulic fluid.
You could be little low on hydraulic fluid?
I to had the same problem and it was the knob.
I would be most interested in your out come.
Take care Russ and good luck.
Thomas..NH
/ 3pt won't lift
Re: 3pt won\'t lift
Well the B7200 has position control unlike the B7100s. I did not move the knob under the seat but I will check it. I also checked the fluid level and it was okay (and the loader works). Thanks fot the suggustions I will be working on it tonight.
Russ
/ 3pt won't lift
Re: 3pt won\'t lift
I will try that and see if that works. I did lift the loader, but did not wiggle it to see if it was centered. It almost feels like the internal linkage fell off. The lever (B7200s has Position control btw) moves up and down with no resistance at all. No sign of any problem up until this morning either... Thanks for the suggestion, I will keep trying.
Russ
/ 3pt won't lift #6
Re: 3pt won\'t lift
Unfortunately, that does not sound like it's going to be the same problem I had with the B7100.
Bird
/ 3pt won't lift #7
Re: 3pt won\'t lift
Russ, I had a very similar problem a few weeks ago on my old yanmar 276...3 pt never every gave me a problem...put it away at night in working order, next morning, 3pt wouldn't budge an inch...after removing the belly mower (which isn't easy on that tractor, checking the fluids, checking for something stuck somewhere, I tried to drop control under my seat...apparently (I think) one of my kids must have gave it a whirl, because after I adjusted it back and forth a bit, everthing worked fine again...keeping my fingers crossed that that is all it was and not a sign of future problems...good luck with yours.
/ 3pt won't lift #8
Re: 3pt won\'t lift
Your havin this problem becasue you bought orange, there pieces of junk, you shouold have bought New Holland BLUE instead. That never happens with BLUE. They make them in the USA instead of China. Thats just my opinion, bvut its right. BLUE is best, then green and not orange ever. I have never tryed a kubota and never will. Kubotahater
/ 3pt won't lift #9
Re: 3pt won\'t lift
Kubotahater,
Now that you have that off your mind do you really feel any better? I'm not really sure if you could've screwed up your facts anymore if you tried! Joking around is one thing, but if you can't add anything helpful...silence is probably YOUR best option.
JimBinMI
We boys and our toys!
/ 3pt won't lift #10
Re: 3pt won\'t lift.....Jim
All he or she (Kubotahater) really shown was ignorance also lack of respect.
How does that old saying go?
Lack of a education can only breed different forms of ignorance.
Did I detect some of your wisdom of being a teacher for so many years to the responds in which you wrote? :eek:)
Hope you have a pleasant weekend and be good to yourself !!
Thomas..NH
/ 3pt won't lift #11
Re: 3pt won\'t lift
I'm with Bird. this may not be the problem, but it's useful to know anyway. Priority selectors seem to feed remotes at the expense of the lift. My grasp of hydraulics is shaky, so maybe somebody will straighten me out if I've got it wrong.
I took off my backhoe recently. When I pulled forward, the lift went to the ground and wouldn't rise. After a short scare, I realized that I left the valve for the rear hydraulics bungeed open (to feed the backhoe). Took off the bungee, and up comes the lift. WHEW.
/ 3pt won't lift #12
Re: 3pt won\'t lift
ditto
Gordon
/ 3pt won't lift #13
Re: 3pt won\'t lift
Myself, I'd just ignore it. This sort of stuff seems to be left over from the days when kids dominated the net, and flaming was fashionable. It's just attention getting from people who don't seem to know any other way to get the world to react to them. If it gets attention, they're always back for more.
There was something similar the other day. I'm happy to see that nobody reacted much. Ho hum, just kids stuff. Well, we all grow up sometime.
/ 3pt won't lift #14
Re: 3pt won\'t lift
Russ, I used to own a Ford 1500 that did the same thing...Yes I did say Ford aka NH (Blue). After contacting the dealer it was a 5 minute fix. The shaft that the control arm bolts to had worked its way loose. on the 1500 there is also an adjustment nut at this pont. check the retaining nut on the end of the control arm shaft. use a back up wrench on the inside nut while tightening the out bound. Hope this helps with your problem and good luck./w3tcompact/icons/smile.gif
/ 3pt won't lift #15
Re: 3pt won\'t lift
Funny, never hated somthing I never tried or knew nothing about....Must be very time consuming hating things like that, seems like there could be so many....Ahhhh...I get it...jealousy can be ugly now cant it?
/ 3pt won't lift #16
Re: 3pt won\'t lift
I had this same problem on my old B20. What happened was the lock valve broke off inside the hydraullic assembly and it prevented the 3pt hitch from lifting. Good Luck!
/ 3pt won't lift
Re: 3pt won\'t lift
Well not sure what it was. I went out and re-checked everything (oil, linkage, etc.). I started it up saturday morning and presto it worked, strange... I messed around for 10 minutes Friday with no lift at all. Maybe I had the loader valve stuck or something, but I remember moving it up and down with no change on the 3pt. Anyway thanks to everyone on the suggestions. I put 4 hours on it brush hogging without a problem (lots of 3pt lifting).
Russ
/ 3pt won't lift #18
Re: 3pt won\'t lift
Russ,
Glad to hear your 3pts hitch is working once again.
Sounds like Bird hit the nail right on the head.
Have fun and stay safe.
Thomas..NH
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2018 CATERPILLAR 303.5E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2018 BMW X1 28I SUV (A61569)
2018 BMW X1 28I...
Land Pride BB1260 (A62177)
Land Pride BB1260...
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A61165)
2022 Ram 3500...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
