3pt weight capacity??
   / 3pt weight capacity?? #11
I checked an old piece of literature as well as some other reference material that I have here and I found no reference to the lift capacity of the three point hitch. The basic chassis is the same as the 2150 and I feel you would be safe useing the 1014lbs that they say is good at 24" behind your links. There is a .3 difference in pumps but you should be very safe.
Art, in the b9200 book it lists 550# as the max weight of tiller attachment.
   / 3pt weight capacity?? #13
Emery, Kubota is conservative in their weight limitations. Example: The manual for my B2710 lists the 3-point hitch lift capacity as 1655# at the lift point and 1300# 24" behind the lift point. However, it also lists the maximum tiller weight as 550#. As has already been mentioned, they take into consideration such things as whether the front wheels are going to come off the ground, loss of steering capability, etc. Try that tiller and if you don't like it, I'll swap you my 40" tiller for it (366#)./w3tcompact/icons/wink.gif Of course you have to do the transporting./w3tcompact/icons/wink.gif
Bird
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
Landoll Lowboy Trailer (A56435)
Landoll Lowboy...
2005 INTERNATIONAL 9400I MID-ROOF SLEEPER (A58214)
2005 INTERNATIONAL...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
