Backhoe 3pt vs. frame mount backhoe
   / 3pt vs. frame mount backhoe #1
twomanytractors
Central New York
Kubota B7610, Wheel Horse 520H w/44" blower & cab, WH 314-8 w/ 42" mower & snow plow, Sears Suburban SS16 w/ 3 pt, potato plow, rear blade, moldbord plow, discs.
I'm thinking about a backhoe for my B7610. What are the pros/cons of a factory frame mounted vs. aftermarket 3 pt backhoe?
   / 3pt vs. frame mount backhoe #2
Con - Kubota will void your warranty on any physical damage anywhere on the machine if a 3pt hoe is used. (Most all are the same, not just K)
Con - weaker mount and wobbly performance from the 3pt vs frame 4 pt mount
Pro - cheaper by a few hundred.
   / 3pt vs. frame mount backhoe #3
I have the B7510 and bought my 3 pt backhoe from Kubota so I would have the warranty with the tractor and so far after 3 years not a glitch!!
   / 3pt vs. frame mount backhoe #4
con: parts of your body between tractor and hoe = possible large dr.bills
pros: none except a few $ cheeper
   / 3pt vs. frame mount backhoe #5
Do a search on here and you will get alot of comments and information. There are alot of threads on this subject. Most will tell you to get a subframe.
   / 3pt vs. frame mount backhoe #6
Some people have had the tractor break in half with the three pointers. :mad:
   / 3pt vs. frame mount backhoe #7
I have the same tractor with a Woods 70X subframe BH. I can't speak for the 3 PT type, but I really like how solid the unit feels. I supose if you change a lot 3 PT implements, it would be a plus. Personally, when I put the hoe back on after winter, it generally doesn't come off until next winter for the blower.
   / 3pt vs. frame mount backhoe #8
Con -dangerous if something breaks it can crush you.
   / 3pt vs. frame mount backhoe #9
Yes, both the Kubota 4672 and the 4690 hoes are 3-pt hoes sold and
warranteed by the company. Even Kubota admits they are not consistent
with company policy re OTHER companies' 3-pt hoes. Go figure.
Wow, glad I asked. I was not aware of the potential damage or warranty issues. I would not want to explain to the dealer (or my wife!) how my tractor split in half! So
So my next question is, how difficult is it to install & remove the Kubota frame mount hoe from this tractor?
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
(INOP) 2001 KOMATSU WA250-3MC WHEEL LOADER (A51242)
(INOP) 2001...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2018 FREIGHTLINER...
