3pt tilt indicator
/ 3pt tilt indicator #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
I've alway had a problem of getting the implement level (side to side) to the tractor. Most of the time I need to lower or raise the 3pt arm, on one side (counting the turns on the crank), to hook up my implement. Once hooked up I would raise the implement and turn the crank the amount counted during hook-up back in the other direction. Then stand back and look to see if the implement was level with the housing on the tractor. Also the same was done when using the blade or rake to slope grades or crown roads. Its a real PITA! So I made up this indicator. Basically it works like the loader bucket level indicator, the tube and rod type. It took about 1/2 hr to get to the point seen in the attached picture. Had about $9 in steel, of which I only used 1/3 of. After leveling the implement I removed it (indicator) and cut a notch in the rod indicating level. Cleaned it up a bit and coated a few times with paint. The rod is cut to a length so when it is flush with the tube, there are still enough threads on the adjuster to safely use (for lifting). A few times I was cranking and the rod threaded all the way out and came apart.
I'll post pictures when it is all finished.
I think this idea would work really well with a hydraulic tilt. Many be even with an indicator (cable, etc.) mounted in the cockpit.
Another view.
Another view of the whole rear end.
/ 3pt tilt indicator #4
Derek,
I like the concept. I too have the same problems, particularly when grading the crown of my driveway.
My adjustment arm is different than yours. I will have to look at yours for a while to determine how I can make something like that work for me.
Great idea!!!
Can you snap and post a picture of your adjustment arm? Maybe we could figure something out?
/ 3pt tilt indicator #6
Derek,
Here is a picture of my adjustable side link.
I just came in from grading my road and had to guess on the adjustment that works well. Your system would be of help.
Something like this? You could put on either the outside as shown or on the inside. Also you make a bracket, come off the fork (top and bottom) and use a 1/4" bolt. The drawn in part is not to scale.
/ 3pt tilt indicator #8
Looks like it would work. I need to have good access to turning the side link by hand. Depending on the weight of the implement I need two hands to turn the link.
Thanks for taking the time to sketch it out. What I really "want" is top and tilt so adjusting would not be a big deal.
100 Gallon Galvanized Water Tank (A65579)
100 Gallon...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
KENWORTH CAB AND HOOD (A65643)
KENWORTH CAB AND...
