3pt Sprayer
   / 3pt Sprayer #11
Continental Belton makes really good 3 point sprayers. But I don't know what the shipping would be to Illinios.
I purchased one of their 55-gallon boomless sprayers (Ag-Meier Industries 3-Point Hitch Sprayers) with a Hypro roller pump through my local Kubota dealer back in May. I also looked at a 55-gallon boomless sprayer from Ag-Spray (https://www.agspray.com/cart.php#!c=224). The Ag-Meier has a lighter frame than the Ag-Spray by about 80 pounds or so. I would have gone with the Ag Spray if I was going to be using the sprayer with my utility tractor, but I bought the sprayer to use with my small Kubota. Although I have 220 lbs. of front weights, I was worried about the extra weight of the Ag Spray unit when topped off.
I have been pleased with the performance of the Ag-Meier unit to date.
Steve
   / 3pt Sprayer #12
Another simple way is putting a garbage bag over each nozzle to catch the output. Then measure it. Continue calculations as above.
   / 3pt Sprayer
If the pump is PTO driven what do you need wires for?
The ones i looked at all had electric pump but people complained about cables not reaching the battery and the flow being severely less than advertised like 35psi vs advertised 80psi..
thanks for replies i shall check out a few of these links here
   / 3pt Sprayer #14
The ones i looked at all had electric pump but people complained about cables not reaching the battery and the flow being severely less than advertised like 35psi vs advertised 80psi.. thanks for replies i shall check out a few of these links here
35 psi should be more than enough pressure for spraying. If you have some time to spend here's some links to teejet. Probably the most used sprayer tip. They have a very helpful website and its full of information. TeeJet - Spray Nozzles
http://www.teejet.com/media/40076/user's guide to spray nozzles_2013_lo-res-sequential.pdf
   / 3pt Sprayer #15
If you're spraying hay fields 35 PSI is plenty.
   / 3pt Sprayer #16
I built mine. I used a 125gal tank, a 7gpm electric pump, and a 14ft boom kit. Pump and boom kit came from Northern tools. Pump is rated for 60psi at 7gpm. This gives me 40psi to the nozzles and the rest is returned to the tank for agitation. Also with the boom kit it came with a spot sprayer wand. Mounted all on a homemade carryall and carry it on my tractor. Added a anderson connector (50amp) on the back of the tractor and a remote switch to control all. So far has worked great.
1983 KENWORTH W900 SLEEPER (A58018)
1983 KENWORTH W900...
CATBKTSSL_78 (A55787)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
1979 KENWORTH TANK TRUCK (A58214)
1979 KENWORTH TANK...
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
