3pt splitter build begins
   / 3pt splitter build begins #1
165masseyky
Bronze Member
Albany Kentucky
massey ferguson 165
After several weeks of thought and research. Trial and error and more error and nearly a trial I have decided my 165 MF doesn't have quite the juice needed to do what I need from my splitter so I am gonna go another direction. Instead of relying on my tractor QD's I have decided to run from a gas engine with a shaft pump. After contacting Northern Tool(who btw has what I believe to be the best customer service in the free world) I have returned the unused belt driven pump that I had traded for and now have $530 to spend toward this project in the form of a Northern Tool gift card. I have located a twin cylinder 16.5hp Briggs engine that I can trade for with little to no money invested. I have chosen a 16 GPM 2 stage 3000psi pump that I will couple to the Briggs and also ordered a 20gal tank with large screw in screen along with a 5in x 2in x 24in Hadaven cylinder.
I do have a concern though. The pump doesn't list a return pressure so I don't know what PSI filter I need to purchase. It is a Haldex pump so maybe someone can help me with this.
The specs I got from my math for this set up should run a very satisfyingly productive system. I also have a Prince LSR 3060 detent valve that would make the extend very quick but could cause some serious hydraulic heat issues I fear.
(without LSR valve)
Push lbs -58905-29.45ton
pull lbs -49480-24.74ton
extend speed-7.7
retract-6.5
cycle-14.2
I know that isn't a blazing speed but with this much pressure and my 1/2in H beam I can make multi split passes with ease I believe as long as my Hydra. temps don't get to high. I was able to trade some with the local hydraulic shop and got the 5in bore for about $150 new. Not bad so I will pat myself on the back now. The H beam was a freebie...well sort of I got it by helping the local scrap yard guy load some steel on a trailer. Took about 3 hours. Built the pusher sled out of scrap I scrounged from the metal bin at work. My hoses I had made and were $227. To this point I have figured I have ruffly $550 in the same materials you would find in a $3000 splitter. Now the work starts. I have a 4x8 diamond plate decked trailer that is going to be sacrificed for the frame and transport unit.
So here is what I am thinking. How bought we do this as a group. Lets here suggestions of what would be a good thing to have engineered into a splitter and what things have been tried and were less than a good return. I want to finish this build and dub it "TBN1". So who is up for this the sky is the limit and no idea is too wild. All suggestions will be considered and in one week we should have enough of a design to start the build. Only restriction is the H beam is 6' 6" long and the rest is up to us.
Might be a good idea to set up a list of details.
.Safety
.Hydraulic
.Power
.Log Lift
.Log stabilizer
.Fuel capacity
.Wedge
.Transport
.Tools and Storage
.Spare Parts
.Paint scheme
After reading tons of posts from this site I think this could be an awesome endeavor an not to mention a lot of fun to see just how far the brilliant minds on TBN can push them selves.
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
1990 International F-4900 Tri Axle Dump Truck (A59230)
1990 International...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
