3pt snowblower woes
   / 3pt snowblower woes #31
I'm with ya! Runnin' much over 2000 rpm doesn't make me real comfortable yet either. We're probably just being silly as I'm sure these tractors are designed to run at the desired pto rpm day in and day out. You don't exactly hear of many engine problems here on TBN anyway./w3tcompact/icons/smile.gif
Jeff
2001 B7500hsd, la302fel, 60"mmm, grass catcher
Ok, I'm going to have to get some ear plugs then I won't mind the engine noise.
Yes, I have hydro so it makes it easy to adjust speed to match snow load.
I also bought a can of PAM and will use it just before each job.
   / 3pt snowblower woes #33
I think this is a major factor in the snow blockage you are experiencing. Wet snow doesn't help at all, but if the blower is running too slow you can pretty much count on trouble like you are experiencing.
I ran my blower at 2000 RMP or so for the first few times because I was still within the 50hr breakin period, and whenI was finally OK to run at full speed the difference was remarkable. It was all in dry snow, mind you, but the difference was clear. All the other suggestions folks have made here are excellend and will help, but if you aren't running at full speed I think you will find yourself in an uphill battle.
Some 3PH implements can be run at varying PTO speeds, and some really require the full 540 RPM. Chippers, mowers, and snow blowers are three than come to mind (probably becasue I have them). Others like winches and backhoes can run at any speed that suits your needs.
As others have mentioned, I wouldn't worry at all about running at full speed. The macine is designed to do just that day in and day out for thousands of hours. Headphones or ear plugs are a must regardless of the speed, in my opinion.
Good luck and I hope you find satisfaction in your snow blower. I'm quite happy with mine.
P.S. You do have the advantage fo multiple PTO gears and could take advantage of it. Assuming your 540 PTO engine speed is about 2600RPM when using the 540 gear setting, then about 1800 RPM will give you 540 PTO RPM in the 760 gear setting. I would recommend AGAINST over-reving the blower using the 760 gear so don't crank the engine up to 2000 RPM inthe 760 setting.
   / 3pt snowblower woes #34
Emery,
I also have a rear blower for my BX (Meteor). It works better than I could have imagined. No kidding, the thing just sucks up anything and wings it quite a ways....including snow :) My only complaint is the amount of shear pins I been through. I've used it three times very successfully and broke three pins.
I can't imagine what is wrong after reading your posts? Sorry to say it but, maybe it's just a poorly designed blower?
2003 Sea Ray SLX 29' (A56859)
2003 Sea Ray SLX...
2015 FREIGHTLINER M2 BOX TRUCK (A58017)
2015 FREIGHTLINER...
2022 Magni TH5 5.19P (A56435)
2022 Magni TH5...
Terms and Conditions (A55272)
Terms and...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2005 JOHN DEERE 317 SKID STEER (A52709)
2005 JOHN DEERE...
