3pt snowblower coversion to bucket attach w/frPTO
   / 3pt snowblower coversion to bucket attach w/frPTO #21
Re: limiting FEL MOVEMENT
Pks:
As long as he doesn't first article test it on a weekend. You know as well as I do that weekends are for beer parties in Houghton-Hancock. Liquid courage can be detrimental to your well being. /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
   / 3pt snowblower coversion to bucket attach w/frPTO #22
Ed I had a massive brain fart about a sweeper I made for my cousins tractor. I monded pillow block bearings under the belly of the tractor one under the back and one under the front. I used 1 1/4 bar stock and ran the shts all the way to the rear. I machined the yoke off and old cast steel snap lock pto yoke. I then bored a sproket out and heated it and pressed it onto the modified yoke. I used a 70 18 to weld it up and then mounted it onto the pto. I took the 1 1/4 inch shaft on the bottom of the tractor and put a smaller sprocket on that end and then I had a PTO that ran under the whole machine. I used his phd drive shaft to make the connection to the sweeper. He doesnt use limit chains on it because it has to be 4 feet off the ground before he has and u joint knocking. Ive done a few of these conversions they work out handy because of all the holes under the tractor at the rear and the front.
The tractor is a John Deere 3010 for those who want to know.
I have a 3D model of the original snowblower for those who want to see what we're starting with.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2013 Infiniti JX35 SUV (A55853)
2013 Infiniti JX35...
