3pt pressure relief?
/ 3pt pressure relief? #1
Scrub868
Kingston. Ohio
Ford 3000. Mitsubishi MT2501FD
Hello all. I have a mid 80痴 30hp gray market Mitsubishi. The 3 point works well as long as you don稚 raise it all the way up. When it is raised up all the way it does not relieve pressure.
I知 guessing it has two pressure reliefs since it relieves pressure fine when the 3 point is positioned anywhere other than full up.
Service manual is not available for the tractor (in English anyways). Any ideas on what the problem could be would be appreciated.
/ 3pt pressure relief? #2
Check the feed back rod and adjust it just to stop just before the lift arm bottom out. It well be a small rod that is hooked to the lift arm and to a small lever that shuts the valve off, some have a small spring around the rod.
Appreciate the suggestion. I will give it a shot tonight.
Did not see the feedback rod you mentioned. Guessing it is internal then? Can I unbolt the top cover and remove it without tearing anything up?? Thanks
/ 3pt pressure relief? #5
No it's not internal. That's about all I can say because I never been up close to a Mitsubishi tractor. I would move the 3pt up and down and see if you see anything move with the upper lift arms. It is real easy to over look.
did Another quick check tonight. Still didn稚 see anything connected to the lift arms. There is a sensing rod on the third arm/top link bracket but I think that is for Draft control operationé*�m I wrong on that???
I have tomorrow off so I will take another look 😩
/ 3pt pressure relief? #7
Yes I would also guess that is draft control.
/ 3pt pressure relief? #9
See page 48 in the manual by radios1.
Likely all Mitsu are the same.
The rod could have fallen completely off which could explain why you cannot find it.
Dave M7040
Really appreciate the input guys. My model is a MT2501fd. Grey market so there isn稚 much support for them here.
I believe what you were referring to in the manual is what controls the lowering speed in the TPH. I have something similar in front of the seat.
While I believe there should be something somewhere to move the control valve to neutral position when TPH is full up�I think my best option at this point is to remove the lift arms and rotate them a few teeth down or put a bolt in the position control lever to keep it from traveling to far. Either option would still allow me to get full travel on the TPH (first option would actually let me get a little lower when it痴 down) and would keep it from overpressurizing the system. Then I can monitor it and see if it gets worse�eck there may not even be anything wrong with it, sprevious owner may have put the lift arms on a few teeth off at some point.
THANKS AGAIN THO. The assistance is/was appreciated.
Psæ‚* ran my hands all over the lift arms they were smooth with no indication of a missing linkage of any kind.
Thanks again!!!
/ 3pt pressure relief? #11
Thanks again!!!
Likely you are going to find their is indexing in the splines to preven you doing what you npropose. It also aids in assembly line work getting the lift arms in the correct place.
How about some photos.
Suggest you contact Piloon who is the Mitsu expert on this forum.
Dave M7040
Took a few pics but can稚 figure out how to link them on the post 😩
From what I can see the lift arm is not indexed and looks like it will be fairly straightforward to rotate lift arm a few teeth down
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
