Posthole Digger 3pt Post Hole Digger (make it tougher)
   / 3pt Post Hole Digger (make it tougher) #1
fcmazz
Texas
I'm having problems digging holes with a 6 or 12 inch auger. I keep buying new teeth on both of them and would like to know if anyone has ideas to improve the "grip" on these teeth so they can continue to dig instead of them just spinning. Thinking of welding something on the auger itself around the teeth area so maybe some metal "fork" looking teeth. Don't know I'm out of ideas. I do have rock and caliche but seems the 45hp Mahindra would do a better job digging past a foot or so. Frustrated..
Thanks for any ideas in advance.
fcmazz:mad:
   / 3pt Post Hole Digger (make it tougher) #2
They do make rock bits for post hole diggers. Takes a while to grind through stone though, and a downforce kit is almost always required for stone (3 point doesn't produce any downforce on its own).
   / 3pt Post Hole Digger (make it tougher) #3
If you have solid full width teeth, you could notch and alternate them like this. That would about double the pressure on each cutting edge.
Post Hole Digger - Rolin Manufacturing
Bruce
   / 3pt Post Hole Digger (make it tougher) #4
I've heard good reviews on Pengo teeth. Google "pengo carbide". Amazon even has a few Pengo teeth for sale.
   / 3pt Post Hole Digger (make it tougher) #5
Keep in mind that your post hole digger might not be designed for the extra stresses involved in auguring through rock.
   / 3pt Post Hole Digger (make it tougher) #6
That's just an excuse to buy the bigger upgraded model. :D
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A57024)
GMC 3500 Extended...
MISC PALLET (A55745)
Ammco Brake Machine (A55758)
Ammco Brake...
