3pt planter ???
   / 3pt planter ??? #1
sigpros
Hi guys new here and love the site. i am wanting to build a 2 row planter for sweet corn. What I have is 2 rows and tool bar off an old Allis planter. The untis are like JD 71. It was an 8 row and the guy took a torch and cut 2 rows off. My question is how to make it 3pt? I can weld just can't figure it out. Anyone have any pics? Thanks Chris
   / 3pt planter ??? #2
Morning Chris,
I am in the middle of building a three row planter right now using the JD 71 Flex planters. What I am doing is using a 6x4 tool bar that is 7' long.
I purchaced 3"x4" angle iron and I am cutting the bottom pieces 12" long and drilling them on the 3" side to bolt up to the tool bar using U-Bolts that I had made up. I am drilling the 4" side for the standard lift pins.
I am then taking two of the 3x4's and cutting them at 14 1/2" long, these will be also drilled to accept the u-bolts and then they will be drilled to accept a top link pin. These will have a piece of square tubing in between them welded and drilled to accept a foot post that I can put down to help balance the planter when put down on the ground.
I am cutting and drilling today so when I am done I'll try and post some pictures of the mock up so you get a better idea of what we are doing.
If you search e-bay for corn planters you will see a lot of one and two row planters that might help you, looking at these is what gave me the idea to do mine this way. Hope this helps.
2018 Dodge Grand Caravan SXT Van (A50324)
2018 Dodge Grand...
2006 CHEVROLET EXPRESS SERVICE VAN (A52577)
2006 CHEVROLET...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
