3pt or Stand Alone Splitter
/ 3pt or Stand Alone Splitter #81
Something I didn’t see mentioned is that the 3pt hitch splitters are all hydraulic. What about kinetic splitters? I have a 34ton DR kinetic that turns 2x75lb flywheels at 400rpm using a 6hp B&S engine. It will blow through most any wood (I’m from New England- all my wood is oak, hickory, heavily knotted is the norm). Do about 12-15 cords per year between me and my sons. Two things become obvious the first time you use it 1. It is fast- 3 sec cycle time. Your rate limiting step is getting wood to the machine- one or preferably two helpers can be kept busy with this machine. 2. It uses almost no gas- you run all day and still have gas in the small B&S tank. My son worked for a commercial wood yard and he said the guys complained about the machine never needing gas so they missed the fill up break they were used to with the hydraulic machines. I hesitated getting the machine because hydraulics are tried and true, but it has made a believer out of me. So my answer to the op would be stand alone kinetic.
6' Fork Extensions (A60463)
6' Fork Extensions...
2019 CATERPILLAR 272D3 SKID STEER (A62129)
2019 CATERPILLAR...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
FRAC TANK (A60736)
FRAC TANK (A60736)
207273 (A52708)
207273 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
