3pt not lifting to full capactity
   / 3pt not lifting to full capactity #31
Tim_in_IA said:
The bale spear that I am using is an older vermeer with 2 spears. It only attaches to the bottom links and has stops and chains that exert the force against the bottom links. Would this have less capacity than a spear that utilized the top link? I didn't think so before since all the power comes from the bottom links, but if there is a lever action that happens this also might be contributing to the issue.
The 7520 loaner lifted the bales fine with the attachment but it has a rating almost 1000lbs higher.
Tim, sorry I somehow missed the last posts on this thread. YES, this arrangement - the one you posted pictures of - loses lift capacity as you move out from the balls. If you were to measure the length of your lift arms (A), and then measure the distance from where the lift arm pivots on the tractor to the "point" on the spears where the weight is being lifted (B), you could have a good idea of what to expect. The lift caacity will be A/B times the lift capacity at the balls. From the pictures Im guessing the fraction A/B is about 1/2. I just had to look back to the 1st to see how heavy those bales are - - I expected about 1Klb which wouldnt have explained it. But 1800 puts it very much into the iffy zone. I imagine your tractor is ok, but while youve got their attention get the mechanic to set your pump relief pressure to to high side of the spec. Springs lose a little bit of their tension during breakin for various reasons. This effect on hydraulic relief pressure is very small unless the seat actually wears. What isnt quite so small is the effect of heat. The spring is a little weaker while warm. The difference in relief pressure may go down 50psi (a percent or 2) in a hot system. This should be allowed for during adjustments made cold. If you can get them to show you where the adjustment is made please let us know.
Larry
   / 3pt not lifting to full capactity #32
Tim_in_IA said:
Galen,
I keep thinking of Mahindra's commercial today where they are picking up 2 tractors from competing brands with a mahindra. That is really selling me the message that this should be no problem lifting a bale. If that is not the case then I'd like a word with their advertising department.
For the commercial you are referring to, we did lift the competitors' tractors numerous times.
Without your top link connected to your hay fork, you will not be able to lift your bale. I believe using a hay fork that connects to the three-point hitch (top link and lower link arms) will solve your problem.
Thanks for all the input guys! I will definitely be getting a spear with the toplink component. I am actually glad it happened though as my relief valve was faulty. Great to find out now instead of later. Time to go attachment shopping!! :)
I have the tractor back but I haven't found a good spear that incorporates the toplink to check the bales out on. I had my pallet forks on yesterday and I was backing up with about a 400lb load and the 3point just dropped to the ground. I moved the lever forward and back a bit and it came right back up. Could this have been an air bubble or something more serious? As a recap I just had the relief valve replaced.
Just thought I would post an update. After getting the relief valve replaced I purchased the king kutter E-511 bale carrier and I moved 2 large bales over the weekend.
   / 3pt not lifting to full capactity #36
Wow Tim, 1 bale a day. Did you break a sweat too? ;)
BTW, an this time I'm serious, how is your dog? I lost track of that thread and can't seem to find it.
Bob_Skurka,
Yeah, I am trying to squeaze in some late fall hay making and I just picked up a couple hesston pt10 mower conditioners. They both have their peculiarities and we got around the field 3 1/2 times and a belt broke. We've had rain on and off so I decided just to bale what I had down and fix the mower and try again if weather permits. Translated to 2 bales. :)
Maybe we'll have an Indian Summer or whatever and I'll get some more. Gotta love used equipment!
My pup is doing great! You can hardly tell except his neck is still a little bigger than normal and the bite marks never grew hair back. For some reason the moderators moved that thread to the rural living list. I guess rattlesnakes don't have anything to do with safety but aligators do :) Go figure. Thanks for checking in on me. :)
   / 3pt not lifting to full capactity #38
Glad to hear the dog is doing well.
We are getting the same wet weather you are (except we get it about a day later than you). But it is on-and-off rain here too.
   / 3pt not lifting to full capactity #39
I have a 4005. Recently I have noticed that the hydraulics seem to be operating slowly. Also, if I have a heavy load on the three point hitch the loader moves very slow or may not lift a moderate load at all. I have made sure the speed control is turned all the way to fast. I have changed the hydraulic fluid and filter. Can this be air in the line or is the hydraulic pump going bad.
Don
   / 3pt not lifting to full capactity #40
Don
Don
Remove the stop bracket on your 3ph speed control and close the speed control all the way. Then with the tractor at an idle put your 3ph lever all the way up and down a few times. When you are in the up position you will here a squeal which is the bypass valve opening. Maybe you have some trash stuck in the bypass valve and this will clean it out. Put the 3ph speed control back the way it should be and put the stop bracket back. Also put the loader all the way up or down and give the joy stick a couple of bumps to clean out the pypass on the loader valve. If this doesn't solve the problem some pressure and flow testing will have to be done on the hydraulic system. It's probably best to take it to your dealer for this. Good luck and let me know if this solves your problem.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia NY
585-343-0770
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
377811 (A48836)
377811 (A48836)
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
UNUSED AGT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SKID...
