3pt log splitter storage
/ 3pt log splitter storage #1
Triguy1
North West Ohio
Kubota bx2360
I am looking for ideas on storing my 3pt log splitter when not in use. Currently setting it down on some blocks with boards on top of them, but I would like a better solution. Anyone build something that works well?
/ 3pt log splitter storage #2
is it a pto model or does it have an engine
No, just a simple 3 Pt hitch model that runs off the hydro, had rear remotes put on the BX2360, works really well.
I have a small out building, really just a oversized one car garage where the tractor lives. So I certainly like the idea of a larger building, but for now I was just thinking of a storage rack of some kind.
/ 3pt log splitter storage #5
can yours stand vertical? like mine. mine only takes up about 2 sq ft
/ 3pt log splitter storage #6
Mine's been just sitting out for years. I'd also like something better. I thought about wheels for the hitch pins so I could roll it into the hay mow.
/ 3pt log splitter storage #7
If you dont have one you need to build a 60 x 80 barn and store it in a loft in the back, that way it wont take up any room needed for other items...
Problem is he will soon need a bigger barn, lol, know I did. Wait a second mine was only 30' x 48' my mistake should have doubled it, lol.:laughing: Barns are like cupboard space the more you have the more junk you will have on the shelves, but hey we can always use more junk.
I really do not think that it will stand up like that, but I am going to take a look tonight, that would helpful. I also like the idea of a cart on wheel, so I can roll it around.
Thanks for the ideas so far. And yes, I will need a bigger barn...
/ 3pt log splitter storage #9
When I got my rampsplitter in 08 I had them make two legs for the back that mount on the 3PT pins and one Y stand pinned on the front. The Y pin is removable so I can lower to the ground for bigger logs.
This setup is easily slid on the concrete floor - I store it on one side of barn - to hook up I slide it out, pin on the center hook, connect the HYD hoses and I am splitting. I have the B21 TLB so I use the BH connection for the Hyd lines - also means I can leave the BH attached.
Takes about 3 minutes to slide out, hook up and go.
Carl
Carl
Sweet, that is the one I have. I may call them about that, or learn to weld. :)
/ 3pt log splitter storage #11
Send the pic to doug and he probably would build the three legs for a reasonable price - I dont remember anymore how much more I paid with the splitter - wasn't too much.
It's 3" x1" U Channel with 1/8" thick 4" sq plates on the bottom of each leg. Then the Y stand is 1" tube steel.
/ 3pt log splitter storage #12
With this vertical splitter, storage is no problem, when unhitched it stands firmly on any sort of surface. The ram can be unlocked and lowered so that you can clear doors and such.
/ 3pt log splitter storage #14
Triguy1,
You could put wheels on the hitch pins, and roll it around, or hang it from the rafters or a log frame. Set two 8 ft logs in the ground and a log across the top, secure them ;and hang the splitter. Could also hang it from a tree limb and cover well. Cap all hoses.
Build a box around it and use that as a work table.
/ 3pt log splitter storage #15
I set my vertical splitter next to the corner post at the back of our property & chain it to the post, so it can't tip. The control valve & hoses are covered with a cut 5 gallon plastic bucket. ~~ grnspot
J_J said:
Triguy1,
With my limited space I like the idea of the rafters. Actually I already built a sturdy table out of some extra 4x4 posts that I had in order to set the FEL on over the top of the wood splitter, but it is tough to get the splitter hooked up when I need it. So far, the Stand with some wheels seems to make the most sense.
Jon
