3pt Jack
   / 3pt Jack #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
Back when I had my 35 Massey I collected all the owners amnuals and shop books I could find. In one of the owners manuals there were instructions on how to use your 3pt hitch to jack up the rear of the tractor.
I didn't get it then and don't get it now. Has anyone come across this.
   / 3pt Jack #2
I am not sure if this is what you are talking about but I have a rear end jack in the barn that was made for a 8 or 9 n ford and will work on a massie. It is a frame with two u shaped cups that fit under the axes and i guess you hook it to the 3 point to cantalever it up off the ground. When i get the chance i will take a picture of it.
   / 3pt Jack #3
Our Ford 641 came with a couple of frames that mounted to the 3-pt and were used to raise the back off the ground. My dad used this to widen the tractor by swapping sides with the wheels so the offset was reversed. I was just a kid but I remember his struggling to roll the loaded tires/wheels from one side to the other. It seems you could also change the way the frames fit against the tractor and raise the front end up too.
But that has been more than fourty years ago.
RSKY
   / 3pt Jack #4
On my 4010, I can easily raise one of the rear wheels by placing a floor jack underneath one side of the frame/differential area just below the 3pt.
   / 3pt Jack #5
I found these on Youtube.
[ame=http://www.youtube.com/watch?v=6Eel6aWmvwk]Ferguson Tractor Jack - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=-ZR_bZr69p4]Ford Ferguson 3point linkage jack 9n 2n - YouTube[/ame]
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
greenworks (A53421)
greenworks (A53421)
2009 INTERNATIONAL PRO STAR+ (A53843)
2009 INTERNATIONAL...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
