3PT Hydraulic Level Neutral Position
   / 3PT Hydraulic Level Neutral Position #11
rmc,
Mine almost never returns at the bottom, but always does at the top unless the engine is at a complete idle. Then, it sometimes takes it a few seconds, but once you hear the relief go, it usually returns on its own. I've got a little under 30 hours on it, and it's behaved that way from the start. As somebody else mentioned, I don't think it hurts anything at the bottom because there's no pressure built up.
Kevin
Cup149
Looks like I have the same problem with the black plastic. Used WD40 on the plastic and it moved, put pressure to the side of the black plastic and it returned to the neutral position. The level needs to be bent so that it is in the center of the slot in the black plastic. TBN memebers supply another fix
Thanks for ALL the inputs.
   / 3PT Hydraulic Level Neutral Position #13
I wish the BX2200 had a stop device in the plastic top that I could use so I could stop the box scapper at the desired level every time.
Guess I should have bought a tool that could do that. The old Ferguson had it......
Other than that and looking over the shoulder all the time I am happy... Tom
   / 3PT Hydraulic Level Neutral Position #14
That would be called Position Control. This is available on the larger B2410, the BX nor the B7500 have that feature unfortunately. J
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2018 JAGUAR XE (A56859)
2018 JAGUAR XE...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
23091 (A55758)
23091 (A55758)
2012 ADDCO S/A Towable Arrow Board (A55973)
2012 ADDCO S/A...
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
