3Pt Hitch will not lift.
   / 3Pt Hitch will not lift. #11
Did you check the Descent valve (little knob just under the seat).
My foot has occasionally hit that and turned it off.View attachment 751446
Actually, on Kubota's it's advantageous to crank it one way or the other frequently as the needle bleed valve has a bad habit of getting stuck and while not hard to repair, on a cab tractor it can be a royal PITA to get to.
Do you have the backhoe attached? That one from the other thread.
No, it's not. But we have solved the issue. Seems that when we lowered and disconnected the backhoe, it must have jammed the hitch in the lowered position. We 'jerked' the lower hitch arms around a bit to make sure everything was free then tried it and it started working. When we lowered it with the backhoe on it, it seemed to lower harder than usual, so pretty sure that's when it happened. Thanks for all your help though.
Problem resolved...thanks all!
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
LOT: (10) Fuel Cans (A59076)
LOT: (10) Fuel...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
MASSAGE CHAIR (A58214)
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
2010 Freightliner Derrick Digger (A55973)
2010 Freightliner...
