3Pt Hitch will not lift.
   / 3Pt Hitch will not lift. #1
grtcrowd
Kubota B2320
I have a Kubota B2320 that the 3pt hitch will not lift. It has been working fine but now acts like it's just DEAD. Can anyone suggest where to start?
   / 3Pt Hitch will not lift. #2
You said: "now acts like it's just dead". So, what changed on the tractor between before and now? Do you have remotes, with detent in particular? Maybe you accidentally hit it.
   / 3Pt Hitch will not lift. #3
One thing to check if you have remote valves with detents...make sure a lever has not inadvertently gotten bumped into a detent ...
   / 3Pt Hitch will not lift. #4
Did you check the Descent valve (little knob just under the seat).
My foot has occasionally hit that and turned it off.
No remotes. The tractor was sitting still in the same place for several days while we were working on an attachment. We had raised and lowered the hitch several times during that period with no issues. Lowered the hitch, went to raise it again and got nothing.
   / 3Pt Hitch will not lift. #6
I was gonna say the desert valve also..
I will go check that out. I have been on/off a lot lately and possibly hit it.
Nope. That wasn't it! When I try to lift it, I can hear a bit of strain which is what I normally hear, but see no movement whatsoever.
   / 3Pt Hitch will not lift. #10
Do you have the backhoe attached? That one from the other thread.
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A52141)
2018 PETERBILT 579...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
John Deere Z930M (A50121)
John Deere Z930M...
Bobcat 709 Skidloader Backhoe Attachment (A50774)
Bobcat 709...
