3PT Hitch valve doenst seem right. TC33D (New)
   / 3PT Hitch valve doenst seem right. TC33D (New) #1
Anonymous Poster
Epic Contributor
When i pull back on the 3pt hitch handle to lift the hitch it works fine until I get all the way up and then it bogs tractor down as the relief valve kicks in and stays that way. I can here a click in and out from somewhere on the tractor when i move valve in the last 1 inch of travel. I dont think that should do that. You should be able to pull back all the way and leave it without the relief valve kicking in. I have to push it back down an inch to keep it from doing that. I think out of adjustment what do you guys think?
Roto
   / 3PT Hitch valve doenst seem right. TC33D (New) #2
</font><font color="blue" class="small">( I dont think that should do that. )</font>
I agree. I know how to make the adjustment on a Kubota B2710 to fix that problem, but I don't know on the New Holland. I would expect the adjustment to be described in the manual as it is with the Kubota, but it may not be. At any rate, I'll bet it's a simple adjustment that either your owner's manual or your dealer should describe for you if no one on this forum does.
   / 3PT Hitch valve doenst seem right. TC33D (New) #3
Mike,
Do you have a drawbar pickup hitch installed for a trailer.
On mine, the pickup hitch arms lift the drawbar hitch the last 0.5" of travel on the arms to operate the locking trip mechanism. I then have to drop the arms a fraction for the drawbar weight to be taken off the arms.
The attached photo might clarify my configuration
Nigel
I dont have the the pick-up hitch you describe. I can see what will have to be adjusted and I think it will be easy but will call dealer and have them make sure. This tractor seems to have adjustments for everything but getting at them is the hard part. /forums/images/graemlins/grin.gif
   / 3PT Hitch valve doenst seem right. TC33D (New) #5
roto,
I don't know if this could be your problem or not but it is easy to check so I will pass it on. On my TC29D if I install the pins for the arms as close together as they go, then pull the hydraulic arm way up it will make that same noise. I just happen to run into that by accident. So I just allow the arms to spread out some from the closet setting. Now I am not sure if this is the same thing but it is an easy check. Also my MMM has to on to do it.
murph
   / 3PT Hitch valve doenst seem right. TC33D (New) #6
Roto,
There is a adjustment rod under the fender behind the rear tire. If you turn the adjusment nut to lengthen this rod it will fix the problem with the relief valve spitting off.
I have attached a pic so you can identify it. this pic was taken from in front of the tire.
hope this helps,
Thanks guys! The adjustment is shown in the owners manuel. I overlooked it the first time i went through it. It needed adjustment. Thanks again!
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
