3pt. Hitch on X585
   / 3pt. Hitch on X585 #1
bartdude60
Is it worth it? Meaing is the tractor capable?
   / 3pt. Hitch on X585 #2
It really depends on what you are thinking about using it for. I know the lift capacity is limited.
   / 3pt. Hitch on X585 #3
Do you already have the tractor now? Or are you buying one and interested in that option?
   / 3pt. Hitch on X585 #4
I have the same question along with how much would the 3 point hitch cost and could I install it myself. I have a X595 and I'm mainly looking for some type of carry all that I could move stuff around with. I also might consider a box blade in the future. I ordered the 60" grader blade to level some dirt after having a pool installed but by the time the blade had come in, the dirt which is clay had settled and I couldn't do much with it. A box blade would probably have done what I wanted to do. Lesson learned. I do have to say that the X595 is a great tractor.
Curt.
   / 3pt. Hitch on X585 #5
I also have a X595, and put a 3pt on it when I bought it several years ago. I use it very infrequently. It was expensive. And I couldn't justify the rear pto to go along with the 3ph to enable attachments like a cultivator. So any app's to use the 3ph is limited to smallish blades, smallish box scrapers, smallish landscape rakes -- all of which are embarrassingly expensive if you buy from the JD line. And they're rather light, which compromises their usefulness.
Thank god I also have a JD4700 to take on the serious work.
The 595 is great for mowing on slopes though, which is my primary need.
jim
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50323)
2016 Big Tex 14LX...
Backhoe Attachment (A50322)
Backhoe Attachment...
John Deere 3025E (A50120)
John Deere 3025E...
