3PT Hiccups Ford 1700
   / 3PT Hiccups Ford 1700 #1
triton5150
i have a ford 1700 with a loader. the loader has gotten slower and now hot or cold my 3pt hiccups. one of the lines to the loader pulses as the three point hiccups.
   / 3PT Hiccups Ford 1700 #2
Check the fluid level.
Wedge
   / 3PT Hiccups Ford 1700 #3
How about a little more detail.
Bill
   / 3PT Hiccups Ford 1700 #4
Is the hydraulic supply to the loader via quick couplers?
   / 3PT Hiccups Ford 1700 #5
I have the same hiccup problem with the lift on my ford 1720 year 1990 3047 hrs. and hope you get your problem solved. I've been reading the manual but can't figure which valve to check first. it may be worn O-rings or sticking check valve etc. so I'm just going to try to start checking the easiest first. My lift raises fine but hiccups in any position so I think the pressure is good or I would start with checking the pressure.
2009 Chevrolet Trail Blazer SUV (A51694)
2009 Chevrolet...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
2019 DODGE RAM 3500 (A52472)
2019 DODGE RAM...
JOHN DEERE 54D LOT NUMBER 162 (A53084)
JOHN DEERE 54D LOT...
