3PT Hiccups Ford 1700
   / 3PT Hiccups Ford 1700 #1
triton5150
i have a ford 1700 with a loader. the loader has gotten slower and now hot or cold my 3pt hiccups. one of the lines to the loader pulses as the three point hiccups.
   / 3PT Hiccups Ford 1700 #2
Check the fluid level.
Wedge
   / 3PT Hiccups Ford 1700 #3
How about a little more detail.
Bill
   / 3PT Hiccups Ford 1700 #4
Is the hydraulic supply to the loader via quick couplers?
   / 3PT Hiccups Ford 1700 #5
I have the same hiccup problem with the lift on my ford 1720 year 1990 3047 hrs. and hope you get your problem solved. I've been reading the manual but can't figure which valve to check first. it may be worn O-rings or sticking check valve etc. so I'm just going to try to start checking the easiest first. My lift raises fine but hiccups in any position so I think the pressure is good or I would start with checking the pressure.
2004 Ford Taurus Passenger Car (A51694)
2004 Ford Taurus...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2001 TRIPLE E INDUSTRIES 48X102 TRI-AXLE STEP DECK (A52472)
2001 TRIPLE E...
