3pt disk harrow parts ??
/ 3pt disk harrow parts ?? #1
jjlite
Bronze Member
U.P. MICHIGAN
mahindra 4035
I picked up a disk harrow and am having problems finding a part any help would be great. One of the disk sets had a broken cast friction bearing housing. the spool is 7 1/2inch and has one raised rib that rides in the two cast bearing housings the top half of the housing has #D4070 and the bottom has a #D4075 the axle is 1 1/8 the bolt holes measure 3 1/8 to centers and the length of the housing is 6 1/4 long. If anyone knows where I could buy these parts and would let me know it would be a huge help! I would change the whole assembly if I have to the problem seems to be the 3 1/8 centers for mounting and the 1 1/8 axle shaft. The only numbers on this disk is the ones on these bearing housings. The disk angle frame is red with 20 16 inch black steel disks. paint looks original.
jjlite
/ 3pt disk harrow parts ?? #3
jjlite
Can you post a pic of the boxing assy? Ken Sweet
/ 3pt disk harrow parts ?? #4
Check agrisupply.com
Found a guy that can weld the one I have.Thanks people for the help.
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
(INOP) 2012 INTERNATIONAL DURASTAR 4300M7 SBA TRUCK (A59823)
(INOP) 2012...
2018 Bomag BC572 Articulated Trash Compactor (A59228)
2018 Bomag BC572...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
2006 Formula 292 Boat with T/A Trailer (A59231)
2006 Formula 292...
