Backhoe 3pt backhoe question
/ 3pt backhoe question #1
dty
New Jersey
Kubota 7610
Hi everyone /forums/images/graemlins/smile.gif
I have a 3pt backhoe question. I have a B4672 backhoe on my B7610.
What position should the 3point lower link arms be in - up or down?
Thanks!
/ 3pt backhoe question #2
The manual for my BL4672A backhoe says down.
The lower link arms should be resting on or near to resting on the pipe/bar from the backhoe like in the attached picture. My BL4672A is also an a B7610.
/ 3pt backhoe question #3
You may also find that replacing the stabalizer chains with telescoping arms makes general 3 pt implement changes easier and makes it easier to put the backhoe back on. Here is a thread here on TBN where I switched to the telescoping arms.
thanks Dave. I couldn't find that info in my manual. Thanks for the conversion info too. That looks great and I will definitely do that soon.
/ 3pt backhoe question #5
Hey Dave, did you loose something on the floor, there, in that pic? /forums/images/graemlins/grin.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/blush.gif
/ 3pt backhoe question #6
Yeah, I did. Funny story goes with those rags too. Story is in the 3 pt thread I refer to, but I'll repeat it.
My grandson noticed I had old underware in my tool box and asked why. I told him it was used as a cleaning rag. He said: "ugh, how gross," made a face and walked away. My son-in-law was there and we both had a good laugh over that. A few years have passed now and my grandson is interested in dirt bikes. He'll discover all on his own about rags and how important they are.
By-the-way, I really like your avitar.
/ 3pt backhoe question #7
</font><font color="blue" class="small">( thanks Dave. I couldn't find that info in my manual. Thanks for the conversion info too. That looks great and I will definitely do that soon. )</font>
That backhoe manual isn't laid out very well. I just went through it this past week looking for hydraulic fluid type and quantity. I just happened to remember seeing the instruction.
/ 3pt backhoe question #8
My B4672/B4690 manual has the note about keeping lever down on page 36. Lower left side.
/ 3pt backhoe question #9
Hey folks -
Question for you: since you both seem to be using a 3PH backhoe - do you have any regrets / worries / "wish I'd bought a subframe mount instead.."
Reason I'm asking: I've got a number of stumping / rock removal projects to complete - the local home & garden center apparently raised their rental rates - so I'd run me @ $500 / weekend for a TLB rental.
I'm reviewing my "BH To Do" list - and I'm getting close to where an outright purchase is starting to make economic sense. I took the liberty of asking my dealer - they quoted me @ $5500 for a 3PH Woods B6500 - which seems like a pretty good deal - that's 11 weekend rentals. I think the "convenience" of saying "it's dry out - so let me tackle that stump" - rather than hoping for a dry spell over a weekend is just more practical. (We've had a soggy spring here in New England - so things have been delayed..)
My limitation: I have a MMM - so apparently this cannot be used with a subframe-mounted BH...which most people seem to think is preferrable for heavy work. I'm not planning on continuous "heavy-duty" work - just some occasional stuff....but enough now to make a BH purchase potentially justifed.
Any feedback appreciated!
Dan
/ 3pt backhoe question #10
I have a B7800 with a sub frame mounted backhoe. I havn't removed it yet, but it looks easy to remove the backhoe and frame. You would want to remove the backhe when mowing to reduce the weight of the tractor on the grass. Considering this I would suggest the sub frame backhoe.
Guy
/ 3pt backhoe question #11
Dan,
I have the B4672A on my B7610. Of the 40 hrs on this TLB maybe 15 have been on the BH. So far no regrets.
Prior to purchase I read many of the posts on this board RE: 3pt vs. subframe. For that reason I too considered the Woods 6500. In comparing specs, I found the 4672 to have greater digging force:
Bucket - 2950# vs 2600#
Dipper Stick - 1740# vs 1280#
While I don't know for sure, I believe the "matched set" may have better resale in the future (but cost me ~$200 up front).
I don't have a MMM but have been TOLD that it can be mounted w/ the 3pt BH in place and pinned up for transport (FWIW). Perhaps a member w/more experience can amplify on this.
IMHO, I doubt you could go wrong either way.
/ 3pt backhoe question #12
guyrj33 / edski -
Thanks for the feedback...
In regards to the MMM - I think the BH subframe interferes with the mounting of the MMM. I know for a fact that there are "connecting links" from the lower arms of my 3PH that connect to the linkage under the center of the tractor - these are what lift the MMM. I'd think that one issue is that these connecting links MUST be removed when the 3PH backhoe is mounted.
I wonder if I could mow with the MMM just in the "down" position?
When I asked the dealer about the BH - THEY asked me if I had the MMM - and (I assume) that's why they pointed me at the 3PH model.
It would make sense if at least the Kubota subframe model WERE compatible with the MMM...
I do remove my FEL for mowing - I would also leave a BH off - as I said - this wouldn't be a "daily use" attachment...
The dealer said if I went subframe on the Woods - that I'd have to remove it to use the MMM...not exactly what I had in mind....
edski - thanks for the Kubota vs Woods specs - I hadn't even considered the capabilities. I know where you are coming from re: resale - and I remember someone else commenting that if Kubota designs a 3PH BH - then the CUT should be capable of dealing with its' forces.
I think I'll ask about the Kubota BH pricing as well - don't mind spending a *little* more - especially if the 'Bota has improved performance.
Dan
/ 3pt backhoe question #13
I have a MMM. Thats why I went with the 3PH BH. I can leave the MMM on the tractor with the BH on. But must pin it in the up position. I cannot lower the MMM if BH is on tractor.
I find the BH can be a pain to put on tractor. It has gotten easier after doing it a few times and making a dolly to set it on when not using it.
As for power it does everything I planned on it doing.
Make sure the BH you buy has the separate pump. The <font color="orange"> Kubota </font> has a sperate pump.
I paid what you are being quoted for the B6500 2 1/2 years ago, for my B4690. Prices sure have changed.
/ 3pt backhoe question #14
First a qualifier: I don't have a mower of any type.
I haven't ever paid any attention to the fact that my backhoe is on a 3 pt mount. I use it more that any other implement. 60 hours total on the tractor and about 40 of 'em on the 'hoe. I've used it for some fairly tough excavation work. I've dug up boulders that took me longer to roll out of the hole than it did to dig it free. Some I couldn't even lift with the loader.
I've not done much tree root ball digging, like some folks here on TBN have, which is probably tougher than boulders. I've only attacked one root system (an oak) that took me more than an hour to dig up. The longest non-productive digging I've done is trying to break up some [not yet decomposed] granite shale. I've found I can dig through the shale when it's wet. But when I tried it was dry and hard as the rock it had become. Lots of bucking and seat time but not much progress.
Absolutely no regrets about getting a backhoe. I've been even thinking about a new B2630 with the longer reach BH75. But, the price difference will likely keep me where I am.
When digging with the 'hoe, I put the front bucket cutting edge down and raise the front of the tractor to where the front wheels areonly carrying part of the weight. Same with the outriggers and the rear tires. A firm stable platform makes digging easier. Some others have suggested I shouldn't do this because of the 3 pt mount. I used to raise the tractor tires completely off the ground. My compromise is now I just take a bunch of the weight off the tires.
/ 3pt backhoe question #15
</font><font color="blue" class="small">( I find the BH can be a pain to put on tractor. )</font>
This is part of the reason I like my Woods subframe. It goes on and off easier than 3PH implements.
Money can be saved by using the tractor hydraulics rather than a PTO pump, and may give a better response from the backhoe. You will need to compare your tractor's specs to the PTO pump. On a B7800, the tractor hydraulics win by a nose. But there are benefits to a PTO pump, including reducing risk of contaminating the hydraulic fluid.
/ 3pt backhoe question #16
</font><font color="blue" class="small">( Question for you: since you both seem to be using a 3PH backhoe - do you have any regrets / worries / "wish I'd bought a subframe mount instead.." )</font>
I have a 4690 on a B2910. I think I'd prefer a 4 point mount like the BH 75 or BH 90 over the 3 PT. However having said that, I think I really would have preferred a used mini-excavator, although I'm not too sure on how good of a unit I could have gotten for what I paid for the backhoe ($6500.) The main advantage the tractor mounted unit has is it can be moved around fairly quickly to different locations. In any case, I wouldn't want to be without one or the other.
/ 3pt backhoe question #17
rswyan -
Thanks for the comments. From what I've read here - the "4 Point" (ie subframe) mounted BH's are pretty simple / quick to mount / attach (as aloha pointed out too).
My main "concern" was the "usability / effectiveness" of a 3PH vs subframe mount one. If I had backhoe-ing as a "primary function" - then it wouldn't be a question: subframe.
However, my B7610 is a "mower" first - and a flexible yard-work machine second - so any other attachments have to *work around* the MMM. I think everyone's feedback (especially v8Daves - I've seen the pics of the major work you did next to your shop) - proves to me that the 3PH is still able to perform some hard work.
Now I just need to make my case to the *CFO*.... /forums/images/graemlins/wink.gif
Cheers & thanks to all for feedback....
Dan
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
