Backhoe 3pt backhoe for B7510hst
   / 3pt backhoe for B7510hst #1
hz293
Kalama,WA
Kubota B7510HSD
I have a kubota 21 hp B7510HST and have questions about putting a 3pt backhoe on it.
Will it work without a subframe or will it twist everything?
If it needs a subframe, about how much is it's cost installed?
Will the hoses used for the hydraulic top link tilt be sufficient?
Harris
   / 3pt backhoe for B7510hst #2
Hi Harris, do a search here on " 3pt or 3PT backhoes, click your mouse on word search on top..... a few threads on the subject.. also try "subframe" see what comes up...Guy's have answered the cost question in previous posts...as to using a 3pt hoe...yes and no......good luck
   / 3pt backhoe for B7510hst #3
I have done some research on a backhoe for my tractor which is basically the same as yours. The Kubota backhoe is a 3PT mount with it's own pump and a subframe to strengthen the tractor. I have not heard of a problem with this setup. I did price the subframe by itself and it was less then $200.00.
The pump on this tractor is not big enough to handle a backhoe effectively.
I had decided to buy the Woods which is a frame mount and with it's own pump. However I have not purchased it yet. The best price I found was just under $6000.00
Daniel
   / 3pt backhoe for B7510hst #4
The Kubota subframe is not a subframe in the Woods sense of the word. The Kubota unit still mounts to the three point hitch. I have the Kubota subframe on my tractor.
   / 3pt backhoe for B7510hst #5
I have a B7500 with the Kubota 3ph backhoe - never had any problems with it at all. Works great. As Dan mentioned it has its own PTO pump.
72" Quick Attach Grapple (A56469)
72" Quick Attach...
WOLVERINE TF3-66-2600G PIN ON PALLET FORKS (A57192)
WOLVERINE...
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54757)
(2) LITHONIA...
2020 Nissan Altima Sedan (A55853)
2020 Nissan Altima...
2009 Nissan Maxima Sedan (A55853)
2009 Nissan Maxima...
