3pt arms
/ 3pt arms #1
thomas9n
roanoke
jd3032 1951jdmt
iv'e had my 3032 for three weeks now,and have used four different attachments. when i have to adjust three pt. arms they don't move real easy, so i use a adjustable wrench and am scatching the adjustment arms. ive greased the arms but still need to use the wrench, ive got old er tractors dont mind scatching them a little but hate doing this to the new one! thought about cutting the right size wrench in half to turn them easier anyone else have this problem? tom
/ 3pt arms #3
Are you talking about the sway control adjustment using the turnbuckles? On my 3032, I can turn the turnbuckles by hand once the lock nut is loosened (very awkward) and there's no load on the arms. With an implement attached, I raise it and then pull to create slack to adjust the amount of sway. I've got the lower arms set now so that I don't have to do much of this anymore and use Pat's Easy Change hooks to boot. Makes everything so much simpler.
/ 3pt arms #4
Have you consider getting a quick hitch system, I know for myself changing out all the time was a pain with quick hitch it makes things simple, just a thought...
/ 3pt arms
fireman= yes have thought about quick-hitch but my equipment is older and i don't think a quick-hitch will work on all of it
John Deere 980 30' Field Cultivator (A66285)
John Deere 980 30'...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
John Deere 772-A Grader (A62679)
John Deere 772-A...
New/Unused Wolverine Hydraulic Screening Bucket (A65583)
New/Unused...
2015 KENWORTH T800 TRI-AXLE (A65643)
2015 KENWORTH T800...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
