3pt arms - won't go up
/ 3pt arms - won't go up #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My L4200's 3pt hitch arms were stuck in the up position for a year. I finally was able to get them to go down (I think I had the valve under the seat closed before). Now, however, they won't go back up. I have a single control lever on the right of the seat.
Someone suggested that there was a linkage adjustment that might be incorrect, looking for more specifics on that.
Also, could there be any other settings that I might be missing? I thought that the 3pt hitch was always enabled. I am running a backhoe on the single rear remote, and have a loader.
Thanks - JayC
/ 3pt arms - won't go up #2
Did you connect the hydraulic hoses on the tractor together when you took the backhoe off?
/ 3pt arms - won't go up #3
Greetings,
Not familiar with your particular tractor, but on my L35, there is a small handle behind the back of the seat.
You have to pull it out or back when using the hoe, then push it forward when the hoe is removed to send fluid to the 3 point hitch.
This is in addition to what was said above and the valve under the front of the seat.
Hope this helps!
The backhoe is still installed. My 3pt arms are flopped down and resting on the remote hoses - just trying to left them back up and out of the way. I don't know that the remotes are supposed to be connected to anything when the backhoe is removed, are they? I've never removed the backhoe, so I don't know.
JayC
This is in addition to what was said above and the valve under the front of the seat. Hope this helps!
Hmmm....I don't know of a behind the seat lever, however, there might be something there. I'll have to look.
JayC
/ 3pt arms - won't go up #6
When I take the BH off mine, I connect the male/female remote quick connects to each other to complete the hydraulic circuit...similar to the FEL. Is there a chance the circuit controling the 3PH arms is broken/disconnected/clogged somehow? Are there any other hydraulic ailments that would be evidence of a clog or something? FEL and BH work fine? Any belly links? They are tied to the same circuit as the 3PH links on my machine...if you have them, do they go up?
Just a few ideas to check.
/ 3pt arms - won't go up #7
JayC
The ones that I have worked on, had to have the Power beyond hoses connected to raise the three point hitch. I am sure that your will be the same. It that isn't right for your Kubota, I am sure someone will let us know.
Everything on the machine works perfectly, other than the 3pt, but I'm 99% sure that is cockpit error - there is no reason to think it is defective). I was unaware of the remote connection requirement. My remote couplers are mounted in a bracket that holds them in position and prevents accidental disconnection. I have to unbolt the bracket to disconnect the hoses - do you have such a bracket? I seem to remember my remote couplers both being female through - would I need to attach a coupling hose. Again, I've never disconnected them, so I'm guessing at this point.
Thanks for the inputs.
JayC
/ 3pt arms - won't go up #9
Jay,
I think you are using your rear remote to power the BH. The control lever for that remote has to be in the forward or rear position to supply hydraulic fluid to your BH. To get fluid to the 3pt. you need that control lever in the neutral, center, position. KennyV.
/ 3pt arms - won't go up #10
Mine are a little different. I do have a 'bracket', but it simply the transition between the "frame hose" and the flexible "connection hose" for my BH. If you have two ends to true rear remote, I guess you'd have another valve in there somewhere. Mine are connected directly to the pump and as such, must always be cross connected and the circuit completed...either through the hoses or through the BH spoolers. As I said, mine are male-female and very logical.
With two females, how would you know which side of the pump is which? Seems when you hook something up, you have a 50/50 shot at having the thing go the right way. That makes me think you have an upstream spooler on the remote that may be in the way and affecting your 3PH operation.
I don't have much 'tractor' experience (made the jump from Craftsman to BX and had never been on a 'tractor' previously), but Mr. Kenny V seems to be onto something. Seems like there is a hydraulic widget somewhere in there that is messing up your mojo.
Hope you get it figured out. Always frustrating.
KennyV said:
Jay,
Correct - I am using the rear remotes. Where is the control lever? Is that the little valve that's down by the hydraulic fluid filter?
Thanx - JayC
PS - This past weekend, I used my backhoe to dig a hole for the sole purpose of filling it back in. My wife busted me...I'm so ashamed.
/ 3pt arms - won't go up #12
The selector by the filter is for the loader…if you remove the loader you must turn the slot from vertical to horizontal…
To locate the control for the rear remotes just follow the lines from the female connectors mounted on the tractor… about a foot from the quick couplers you will see them enter the tractor. That point is the control valve. It should have a valve control handle going up and into the operators space on the right side of the seat. If it is not there the previous owner may have removed it, because he never had intentions of removing the back hoe. KennyV.
Hmmm...very interesting. I definately do NOT have a control lever where you are describing. The only controls that my 4200 has to the right of the seat is the 3pt height control lever and the PTO engage control lever.
Maybe there's something hidden somewhere. Dang, I'm going to have to drag out my manual. I hate that...
Thanks Kenny - JayC
Thanks for all the inputs guys. I figured it all out today - spent the entire day battling with my beast.
Turns out that there is a high-pressure-side hose up by the loader control that has to be hooked up to run the 3pt hitch. The hose is either connected to the backhoe remote or the 3pt.
The backhoe connections are both the same, female, and have a brilliantly simple bracket that mounts the coupling sleeves to the tractor. When you yank on the hose, the coupler slides inside the sleeve and the hose pops out. A great feature for the backhoe, since if you forget to unhook the hoses and drive away, the hoses both pop off w/o damage. And yes, I did exactly that.
I never did get the 3pt running - I got distracted trying to get my backhoe off of my tractor, which I failed at BTW. One of the backhoe hoses was apparently made too short, so the subframe couldn't be lowered far enough for me to clear the rear axle bracket and drive off. I could've put blocks under the wheels to lift the rear, but I figured I'd save it for another day. Then I got even more distracted by pulling, cleaning up, and re-setting my backhoe's main swing pins, which evidently haven't ever been done before. I'm gonna need bushings soon.
JayC
2004 International 7400 C&C 017797 (A62613)
2004 International...
2018 Case IH Magnum 380 (A64126)
2018 Case IH...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
AMZ Spray Injection Patcher (A65579)
AMZ Spray...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59914)
2007 TRAILMOBILE...
