3Point custom washers
/ 3Point custom washers #1
rrrkkk
Quincy IL
New Holland TC 30
I have seen them in posts here on the forum, but don't know if they are home-made or store bought. I am talking about a washer that attaches to the lift pin on the attachment and is secured by the lynch pin. It is used to keep the attachment from sliding from side to side on a quick hitch. It appears to be a washer with something welded on one side the size of the lynch pin diameter, the pin is inserted and this keeps the washer in place on the attachment lift pin so you can hook up the quick hitch. hope I have explained it enough.
/ 3Point custom washers #2
Pats quick hitch comes with a number of specially bent and drilled washers fitting your description. Maybe he will sell you some.
larry
Pats are bent with a hole drilled for lynch pin, what I am talking about isn't bent but has a tube like welded onto the washer the lynch pin fits thru.
thank you exactly what I was looking for!
/ 3Point custom washers #6
I looked for the thread that I copied... but could not find it. They were home welded, not store bought. I forget who did it (reason for not finding the post). I made one set with plans to make more (mainly for practice). Here's a couple crappy photos... I can take more this wk/ed...
I hammered the smaller washers to have 90* bend, then welded two of them to a larger washer.
/ 3Point custom washers #7
interesting, to say the least.
/ 3Point custom washers #8
I was just thinking the other day about starting to build and sell these. Need them for mine, just haven't gotten around to building them yet.
/ 3Point custom washers #9
You can buy them (Pat's version) through AgriSupply, they carry the Pat's Quick Hitch products...
Cat 1 part no. is 73966
Cat 2 part no. is 73967
$3.49 for a bag of 2
Not sure about shipping cost.
Nick
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
TEST YOUR BID BUTTON! (A63291)
TEST YOUR BID...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
Gehl RS5-19 (A62177)
