3PH wont raise
/ 3PH wont raise #1
arcteryx
Texas
JD 3032E w/ Loader
Tractor is a L2600DT. Fluid is good but the 3PH won't raise. I have removed the tranny cover and inspected the control valve. When the valve is removed, I can blow compressed air into one of the ports and it does raise the lift arms while on the bench. But when I do this with the control valve on, it does not.
Also, looking at the parts diagram, I don't have the hydraulic piston and 2 orings in the picture attached. This is from the l2600DT parts book. Should I?
/ 3PH wont raise #2
FWIW, I had an IH2505 and the lift arms would not stay up. I finally took it too an IH dealer, who had it for two months, could not solve the problem and charged me a couple of hundred bucks. They told me they thought the engine block was cracked.
I bought my first Kubota and eventually gave the 2505 to a friend of my son. He found the problem!
An incorrect hydraulic filter!
(APPROX 22) 15' 4" - 28GA GALVALUME (A63290)
(APPROX 22) 15' 4"...
2015 Bobcat T770 Compact Track Loader (A64047)
2015 Bobcat T770...
213410 (A64279)
213410 (A64279)
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
