3PH wont raise completely
/ 3PH wont raise completely #1
mcouey
Flintville, TN
Mahindra 2615 HST
I have a Mahindra 2615 HST with 150 hours on it. So I go out last weekend to get her ready for spring cleanup, checking fluids, wires, battery, fuel, grease, etc. Everything is up to snuff except that my 3PH doesn't seem to raise as high as it did before.
I noticed that the 3PH control lever, (a flat steel bar) has bent from torque (twisted) between the 90 degree bend and the connection point beneath the tractor seat. It will still raise and lower, but it does seem to be a bit harder to move than it was last fall.
I'd like ideas and recommendations as to what the problem could be and how to troubleshoot and/or repair it. It's obvious that I need to replace the control lever, but what made it twist??
Please help.
/ 3PH wont raise completely #2
I lost my balance getting on my 2615HST one day and sat on the lever that raises the 3 pt. hitch. Bent it right over enough that I couldn't move it by hand. The bar can be removed and straightened. Just put a pipe wrench on it and bent it back up where it is supposed to be. Check your fluid after you warm it up, you may be a little low on fluid if the 3 pt. wont raise all the way. You don't have your drawbar getting in the way preventing it from going up do you?
No the drawbar isn't on the tractor. Now that you mention it, I have never even used the drawbar! Mostly because I don't know what I'm supposed to do with it, I've only used my Box Blade, RFM, and Loader.
But the bend in the Lever is actually under the seat, near where the lever connects to the hydraulic controls. Is there another place to check/add Hydraulic fluid other than right in the middle of the tractor forward of the seat? That fluid is full.
/ 3PH wont raise completely #4
I wish I could answer your question, but I haven't run into this problem. Lubricate all of the joints & bushings on the linkage. The only thought I can come up with is something, on the linkage,set up during the winter. Other than that thought, I don't have any idea, without looking at it. Wish I could be more help. Good Luck with it.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia, NY
585-343-0770
/ 3PH wont raise completely #5
No, thats the fill location. With only 150 hrs. are you the original owner? If so you may have to ask your dealer. If the flat bar is bent the way you describe, then Galen may me right about the linkage may have froze up or possibly rusted from non use. I spray mine down with PB Blaster penetrant. If the linkage froze the arm may have bent when you tried moving it. Either way the arm can be straightened. Are the stop locks at the full up and down positions which would prevent the lever from going up all the way. The drawbar is used to tow or drag with but most people use the 3 pt. hitch arms with a cross drawbar. I went out and looked at my lever. It has a right angle bend (pic attached). Sorry pic is a little blurry, its due to the 100k size limit here for pics. What is bent on yours? Does it look different than the pic?
George
My handle is bent right between where the numbers 29 and 30 are pointing on your picture. Those numbers are pointing toward the nuts, but if you continue the lines through there, they will bracket the portion of my handle that is bent, twisted actually.
I sprayed all the linkages with WD-40, because that's all I had, but I will pick up some PB blaster tomorrow and hit them again. The handle seems to move a bit more smoothly now.
The stops for the handle are all the way to the ends of the slots, so they aren't interfering with the handle motion.
Oh, and yes, I am the original owner of the tractor, I bought it September 2004, and this is the only problem I've had so far.
/ 3PH wont raise completely #7
The handle can be straightened. I had a similar thing happen with the Kubota at work. The tractor sat all last winter and the linkage froze up from lack of use. The 3 pt. handle got bent by the superman trying to raise the rotary mower so he could take it out for the first mowing of the season. After straightening the handle, I sprayed all the linkage with PB Blaster and physically had to tap the linkage back and forth with a hammer and block of wood till it freed up. Then clamped vise grip pliers on the linkage and worked it back and forth. WD-40 did not work. PB penetrates very well. CRC makes a penetrant as well. I just noticed in my garage that my own tractor is dripping wet with condensation in the air from the rain and warmer weather we are currently having. I'll be spraying mine again before the next use. Hope you get yours freed up soon.
George
/ 3PH wont raise completely #8
mcouey
On my kubota the rod described as #17 has a nut on both sides at the end that #22 is at. This adjusts the height that the 3-pt will lift to. Looks very similar to your Mahindra. Keep in mind that you can go too far with this adjustment and reach the mechanical limits (stop) of the lift. I went to this point and backed it off just a touch so the lift did not seem to labor at the top of it's travel like it did when the mechanical limit was reached. Hope this helps.
*** UPDATE ***
Sorry for the delay, I've been out of town on business, not that that excuses my failure to update the thread on how my bent handle and frozen linkages worked out.
PB Blaster worked. My linkages now move much more easily. I removed the handle, beat it back to it's original shape, repainted it and put it back on. Now that is just dandy.
New problem, I probably should start another thread on this, I will if experienced TBNers advise such. I was on the tractor yesterday for the first time since I repaired the handle and linkage problem. I was moving some mulch from our pile to a flower bed and the tractor revving down, kinda like it would if I was trying to move something heavy in High. So I selected the lowest gear and it kept happening. Even after I dumped the load of mulch it continued. I parked the tractor and came to TBN to search for why this would occur.
I really haven't found an answer for it, so I'll see if anyone here can help.
Mahindra 2615 HST, 150 hours shouldn't need a fluid/filter change on the Hydraulics for another 100 hours. I'm definitely stumped.
/ 3PH wont raise completely #10
Parking brake?
Stuck Wheel bearing?
Differential locked while turning?
3pt hitch rubbing tires?
Thats all the quick checks I can think of
/ 3PH wont raise completely #11
When you R&R the handle did you disturb any wires or the fuel line from the fuel tank? Almost sounds like the fuel pump isn't running and you're running on gravity feed. When you first turn on the key do you hear the fuel pump run? Or maybe you got an air pocket in the fuel line. Other than that I haven't had that happen while on mine.
/ 3PH wont raise completely #12
</font><font color="blue" class="small">( I was moving some mulch from our pile to a flower bed and the tractor revving down, kinda like it would if I was trying to move something heavy in High )</font>
Fuel obstruction?
Soundguy
I hear the fuel pump running when I turn the key on, I will check the fuel filter.
Any tips on how to check the rest of the system for a possible obstruction?
Thanks! For all the help so far.
Checked fuel filter all is fine.
Started tractor and let it Idle for 40 minutes not a single hiccup.
Hopped on and went accross the yard to get another scoop of mulch, before I even got there the engine RPMs started the same thing again.
I noticed that when the Hydro pedal returns to the idle position the engine returns to previous rpms..
Stumped....prolly because I'm a rookie. /forums/images/graemlins/crazy.gif
/ 3PH wont raise completely #15
Hmm.. sounds like the hydro may be loading up... odd. Deffinately out of my diagnostic area on that one... Hopefully someone with rebuild/repair exp ont he hydro units will chime in..
Soundguy
/ 3PH wont raise completely #16
Only thing I can think of is to check on the right side of your motor where the throttle cable hooks up. On the back of the unit is a wire harness. That is the fuel shut off solenoid which screws into the governor, make sure the harness is plugged in all the way. The solenoid, governor, or fuel pressure may be out of adjustment or some dirt may have gotten into the injectors preventing higher running speed and they'll need to be removed and cleaned. Other than that, with only 150 hrs. on your tractor it looks like you'll have to make a trip to the dealer. It should still be under warranty.
***UPDATE****
Thanks to all for the troubleshooting tips. Unfortunately none of them solved the problem. Called the dealer this morning and they just picked it up to take it to the shop. /forums/images/graemlins/frown.gif
Regardless, I know the problem will now be fixed and I will have the tractor in time for the first mowing and finishing up the spring chores. I miss her already.....but at least I know I'll have a ready to work machine when she comes home!
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
2024 Bobcat T740 Track Loader (A63109)
2024 Bobcat T740...
2019 Isuzu NPR Box Truck, VIN # JALC4W169K7009134 (A61165)
2019 Isuzu NPR Box...
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
